Cable Length
0 Members and 1 Guest are viewing this topic. Read 2111 times.
rcj1231
Cable Length
« on: 5 Jul 2008, 09:38 pm »
Is 9 feet of Groneberg IC too much distance from my Candela to my Mono Extreme SE's? I'm moving to a new place and am trying to put the amps in another room (through the floor) from my Candela. Thanks.
Rick
BobC
Re: Cable Length
« Reply #1 on: 5 Jul 2008, 11:07 pm »
I have a 3 meter Groneberg TS Premium IC between my Candela and Mono Extremes and they sound great.
ecramer
Re: Cable Length
« Reply #2 on: 5 Jul 2008, 11:37 pm »
While i don't have gronenburg cables i'm running 3 meter KCI Sound bolts between my Rogue Magnum 99 and my Mono SE's with no ill efect. Should not be a problem i think.
ed
Eduardo AAVM
Re: Cable Length
« Reply #3 on: 6 Jul 2008, 05:02 pm »
As far as I understand Groneberg's Quattro Reference patented design copes very well with long distances, so I think you will have no trouble. It is a great performer.
rcj1231
Re: Cable Length
« Reply #4 on: 6 Jul 2008, 11:46 pm »
Thanks for the responses. I feel better about my plan now. I have some 21 foot sections of Groneberg Quattro cable, formerly used as speaker cable. Can I use these cables to make the IC's ? Or is there some reason that once a cable is used for one purpose, it can't be changed for another? Thanks again...
Rick
