Home audio????
0 Members and 1 Guest are viewing this topic. Read 1549 times.
chgolatin2
Home audio????
« on: 28 Jun 2008, 03:22 pm »
I hired an A/V company to do all the pre-wiring since my house is being built and the walls were fully opened.  I purchase a Denon AVR 4806 with 3 Zone capabilities.  The A/V guy is telling me that I need separate amps for the remaining of the speakers?  Zone 1 will be the Home Theater system the rest of the zones 2/3 are audio speakers for stereo.
I purchase Sonance inceiling and Mariners for outside use.  A total of 8 Pairs.
Is my A/V guy right?  Not sure since I thought I had everything I needed???
tvyankee
Re: Home audio????
« Reply #1 on: 28 Jun 2008, 03:33 pm »
you might be able to route the surround back speaker outputs to the zone 2 0r 3 outputs depending if the receiver gives you the ability to this.
so in a way he is right if you don't have that option. you could always go the multi speaker volume control and go that way so you have independent control over each zone.
there are options like a a-bus system from Russound that is quite good for not a lot of money and will give you a lot of flexibility.
good luck and just look at the owner's manual online and see what your receiver can do.
chgolatin2
Re: Home audio????
« Reply #2 on: 28 Jun 2008, 09:12 pm »
I was informed that I need another amp, any good recommendations for multi zone setup?  Decent price though since I already spent enough on this setup.
Thanks~!
tvyankee
Re: Home audio????
« Reply #3 on: 28 Jun 2008, 09:38 pm »
the only reason you would need to buy another amp for this setup is that you were using your receiver in the 7.1 mode.  otherwise your option's are endless with this receiver according to you manual i found on line.
btw, i know www.partsexpress.com  has some good deals on cheap amps for multi room stuff.
chgolatin2
Re: Home audio????
« Reply #4 on: 1 Jul 2008, 01:15 am »
Any other recommendations??? :scratch: :roll: :cry:
BRILEY804
Re: Home audio????
« Reply #5 on: 1 Jul 2008, 02:43 am »
I sent you an email with a few ideas from the audiogon site the other day, and guess  you havent checked it lately ?
tvyankee
Re: Home audio????
« Reply #6 on: 1 Jul 2008, 03:08 am »
hey
what else are you looking for?
there are a million things you could do but what you said in your post is that your av guy said you needed another amp and thats not the case,
if you really need help pm me and i'll help you through it.
chgolatin2
Re: Home audio????
« Reply #7 on: 1 Jul 2008, 05:19 pm »
Hmmmm, thats weird... I do believe I have check my emails however I dont recall havent anything in my inbox in regards to home audio.  Maybe it went to my junk folder or something but I actually dunno
chgolatin2
Re: Home audio????
« Reply #8 on: 1 Jul 2008, 05:20 pm »
hey
I Just Email YOU!  :wink: aa :thumb:
jamesnicholes
Re: Home audio????
« Reply #9 on: 26 Sep 2008, 05:16 am »
I have installed an advance multi room audio system in my home this stems will allow me to change sources. I could have the CD Changer playing in the kitchen and the XM radio playing in the bedroom. And when the system is playing the music very loud, but when the phone rings the music will automatically mute.and it has many advanced features.
Resource-
Advance Multi Room Audio System
Cheers
James
