External Power Supply for Modded Players
0 Members and 1 Guest are viewing this topic. Read 2690 times.
DTB300
« on: 20 Jun 2008, 02:55 pm »
I will be receiving my modded player back shortly with the external PS.  I looked on the site but could not determine what is the current Rectifier Tube used in the PS.  After listening to the player in stock form for a month or so, I plan on rolling some tubes to see the differences.  I already have some additional 5687 tubes for the player to try out and wanted to pick up another rectifier tube or two for rolling.  I do not want to purchase a second of the same tube, hence my question.
Dan
woodsyi
Re: External Power Supply for Modded Players
« Reply #1 on: 20 Jun 2008, 03:28 pm »
Dan,
I am pretty sure it's 5AR4s on all his tube PS.  I got some extra Mullards you can try -- no need to spend a ~$100 just to find out.
DTB300
« Reply #2 on: 20 Jun 2008, 05:30 pm »
Dan,I am pretty sure it's 5AR4s on all his tube PS.  I got some extra Mullards you can try -- no need to spend a ~$100 just to find out.
Woodsyi...Thanks for the reply.  I know about the 5AR4's but wondered which brand they were using.  Sovtek, Amperex, Mullard, etc.
I do not want to purchase an additional tube to roll and get the same brand
Philistine
« Reply #3 on: 20 Jun 2008, 05:38 pm »
When I had a 999ES with external PSU I believe the tube was a Sovtek.
My tube rolling resulted in a Mullard NOS 5AR4 giving the best combination with 5687's.
MarkR7
« Reply #4 on: 20 Jun 2008, 06:16 pm »
I've also been using a Mullard 5AR4 (NOS, F31 date code) for a while now with great success on the tubed p/s for my Modwright 9000ES.  Recently, after reading the threads here, I have picked up a Tung-Sol 5U4G which I have to admit sounds very, very good.  More swapping is needed, but heck, I think I prefer it at this time, and it was substantially cheaper.  I also picked up a bunch of different 5U4G, 5U4GB NOS tubes to play with.....
DTB300
« Reply #5 on: 20 Jun 2008, 07:03 pm »
So Sovtek is the stock brand of rectifier tube the PS comes with.... ?????????
Do any of you run dampeners on your Rectifier tube?
I personally like Herbie's for my other tube usage and plan on ordering a couple for the 5687, and might as well order one for the 5AR4 while I am at it.
JG2
« Reply #6 on: 21 Jun 2008, 03:06 am »
Herbie's new 'Sonic' line are pretty good and REALLY hold on tight compared to his previous versions.
The Sovtek 5AR4 are no longer the stock rectifier supplied with the Sony 999/9100 PS.
DTB300
« Reply #7 on: 21 Jun 2008, 10:39 pm »
Okay...so what is the brand?
JG2
« Reply #8 on: 21 Jun 2008, 10:43 pm »
I believe it is 'Ruby'.
It is Chinese made, sounds good & has been very reliable.
