0 Members and 1 Guest are viewing this topic. Read 7652 times.
The closest power outlet to my system is a little less than 8' away. I sprung the dough for an 8' Black Sands Violet PC for my amp for a direct connection. I still have the following to plug in:Modwright SWL 9.0 SE preampBolder ultimate power supply for SB3Burson BufferBehringer DCX2496 crossoverThe question is, should I buy a conditioner to plug these items into or just a power strip?I have been thinking about using a PS Audio Duet, Running Springs Haley, Balanced Power Tech CPC or something as simple as a Naim power strip or PS Audio Juicebar. I don't mind spending the extra dough if it will net any improvement. Any comments or suggestions?
What about adding another (dedicated) outlet?
Quote from: woodsyi on 20 Jun 2008, 11:52 amWhat about adding another (dedicated) outlet? best recomendation yet ! while conditioners and outlet strips can work, dedicated circuits are without doubt the BEST way to go. You can then condition them if you so desire.
Hey! This reminded me of my previous apartment. Well, there was one 20A outlet on it own breaker in that place but it was 25 feet away from my room. So, I went to Home Depot and bought 12ga Carol cord some cheap Wattgate plug and IEC and ran the whole system that way. Works great! Definitely much better than running my system from all those 15A outlets in the room of which share the same line as the next room Sadly my current apartment doesn't have any 20A outlet. But I do have one 15A outlet that doesn't have any outlet shared on it line. So, the sound is still good. Take care,Buddy
Try this Naim strip. Can not be beat for the price.Sturgushttp://item.express.ebay.com/ws/eBayISAPI.dll?ExpressItem&item=180255798464&FROM_MERCHANDIZING=1QQssPageNameZKP_Merch_CLOSED_ITEM_SIMILAR_LINK
Quote from: sturgus on 21 Jun 2008, 03:31 amTry this Naim strip. Can not be beat for the price.Sturgushttp://item.express.ebay.com/ws/eBayISAPI.dll?ExpressItem&item=180255798464&FROM_MERCHANDIZING=1QQssPageNameZKP_Merch_CLOSED_ITEM_SIMILAR_LINKYes it can and by over 50%! http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=5339218&MPN=L10320&R=5339218&SEARCH=5339218&DESC=L10320This is the same power strip and I use it as an outlet extension for my BPT. Cheers,Robin
Quote from: satfrat on 21 Jun 2008, 03:38 amQuote from: sturgus on 21 Jun 2008, 03:31 amTry this Naim strip. Can not be beat for the price.Sturgushttp://item.express.ebay.com/ws/eBayISAPI.dll?ExpressItem&item=180255798464&FROM_MERCHANDIZING=1QQssPageNameZKP_Merch_CLOSED_ITEM_SIMILAR_LINKYes it can and by over 50%! http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=5339218&MPN=L10320&R=5339218&SEARCH=5339218&DESC=L10320This is the same power strip and I use it as an outlet extension for my BPT. Cheers,RobinHey! Hmmm.... maybe Naim's version have magic beans in it that why it cost more? Maybe? Take care,Buddy
Satfrat, I'm almost 100% certain he was kidding.
