My Girlfriend Rocks! I need a cheap phono stage..
0 Members and 1 Guest are viewing this topic. Read 5884 times.
sts9fan
« on: 18 Jun 2008, 12:38 pm »
I am super jazzed to say my girlfriend got me a Rega P1 for my birthday!  A nice entry level intro into vinyl so I can start spinnin so black disks.  No I need a cheap/decent phono stage.  I have been eying the Parasound Zphono does any one have experience with it?  I WILL be keeping this <$200 new or used.
fiveoclockfriday
Re: My Girlfriend Rocks! I need a cheap phono stage..
« Reply #1 on: 18 Jun 2008, 12:44 pm »
Never tried the Parasound, I'm sort of half-into vinyl. I use one of these with a bigger than stock power adapter http://www.tnt-audio.com/ampli/t-preamp_e.html. It's nice for <$100, or at least nice enough to maybe tide you over until you can try something else.
sts9fan
« Reply #2 on: 18 Jun 2008, 01:05 pm »
Now I think i am either gonna try a Pro-Ject Phono Box II or Cambridge 540P/640P.  Why because I can go to a store and get them.  Don't want to wait!
JoshK
« Reply #3 on: 18 Jun 2008, 02:41 pm »
Hagtech bugle is probably the best bet on cheap phonos.  Buy constructed or used on a'gon.
http://www.hagtech.com/bugle.html
$149 constructed.
royphil345
« Reply #4 on: 18 Jun 2008, 02:46 pm »
The Cambridge 640-P is probably the nicest phono stage going for under $200.00.  I'd probably go with the Phono Box over the 540-P. The 640-P not only adds moving-coil capability, but it's better quality all the way around. The specs for the 540-P aren't that great.
I know you don't want to buy online, but here's a good deal on the 640-P with free shipping just in case... http://decibelchicago.stores.yahoo.net/caauaz64phpr.html
The moving-magnet only TC-750 from Phonopreamps.com is said to sound better than the Cambridge 540-P for less $... http://www.amazon.com/TC-750-Audiophile-Phono-Pre-amp-Preamplifier/dp/B000A36LQ4/ref=pd_bbs_sr_1?ie=UTF8&s=electronics&qid=1213800313&sr=8-1
I buy just about everything online... The wait is usually not long and I'd probably only have half as much stuff if I paid store prices.
Matt__P
« Reply #5 on: 18 Jun 2008, 03:16 pm »
I picked up a Project Phono Box SE for around $150 and its been a great performer for the money.
sts9fan
« Reply #6 on: 18 Jun 2008, 03:20 pm »
Thanks for the tips guys.  i think I will head down to Spearitsound or Goodwins tommorow.
Kris
royphil345
« Reply #7 on: 18 Jun 2008, 04:14 pm »
A Phono Box SE for $150.00 is a killer deal!!!  Nice...
sts9fan
« Reply #8 on: 18 Jun 2008, 06:31 pm »
Where did you find it for that price?
rpf
« Reply #9 on: 18 Jun 2008, 07:25 pm »
I'm not into vinyl but some friends who are say the Bellari is a good deal. <$200.
John Casler
« Reply #10 on: 19 Jun 2008, 01:42 am »
The Parasound is fine for MM ONLY!!
In fact, I have found it exceptional for the Shure cartridges. (I have the V15 Improved)
But forget it with MC.  It has a noise level that is unacceptable on my Dynavector Karat Ruby.
rajacat
  • Washington State
« Reply #11 on: 19 Jun 2008, 02:39 am »
I just ordered this. http://www.phonopreamps.com/TC-760LCpp.html
It should be here in 3-4 days. I'll give you a short review when it arrives but my opinion might not be all that valuable since I've not been into vinyl for at least a dozen years. It was recommended to me by Jerome on another thread. Judging from the quality of his posts I'd say that he is VERY knowledgeable. http://www.audiocircle.com/index.php?topic=54712.0
-Roy
TheChairGuy
« Reply #12 on: 19 Jun 2008, 03:38 am »
Hey Roy - quite cool.
I, too, have heard that it is a passably good phono pre-amp...replete with MM/MC, (fine) gain controls and it even has Hi/Lo  switch for MC  :thumb:
http://www.vinylengine.com/phpBB2/viewtopic.php?t=8436
It's 12 volts...so you can ditch the weak power supply that it comes with and use the power umbilical as a lead to a new regulated 12v (linear) power supply that you can find as cheap at $20 new or on ebay (for less).
Like this one: http://cgi.ebay.com/Micronta-Regulated-12-Volt-Power-Supply_W0QQitemZ230261320699QQihZ013QQcategoryZ48708QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I have one it it rather remarkably improved my 12v CD/DVD player.
For under $100.00 for the TCC-760 and regulated power supply, you'll have a rather capable phono stage to creep back into vinyl.  Once you do that, RajaRoy - your CD's will be gathering dust  8)
John
Derockster
« Reply #13 on: 19 Jun 2008, 04:00 am »
Hey John would a regulated power supply like that work with the Nad pp2??I know they sell a 1000ma power supply for the Nad but I'm thinking of using something different if possible.Regards derockster
SET Man
« Reply #14 on: 19 Jun 2008, 04:09 am »
Hey!
    You are one lucky audiophile guy there :D
Take care,
Buddy :thumb:
rajacat
  • Washington State
« Reply #15 on: 19 Jun 2008, 06:11 am »
John,
I'm gonna run the TCC-760 off cap reinforced  batteries. No AC grunge for me. :green: I'll, for sure, have the most minimalist, micro priced vinyl rig around here. Free TT (Beogram RX) and $75.00 phono stage. I suppose this will match up OK with the Heathkit monoblocks which should be ready very soon. :singing:
-Roy
doak
« Reply #16 on: 23 Jun 2008, 02:30 am »
I'd say "Major Points" for that Lady.
Bet She has plenty of other good qualities.
Sounds like "keeper".   :wink:
royphil345
« Reply #17 on: 24 Jun 2008, 12:59 pm »
From what i understand... Those regulated wall warts aren't that well regulated. The + or - specs to the target voltage are not usually impressive. You're probably better off going with a regular power supply that's oversized enough where voltage drop during peaks will be minimal. The voltage may not be absolutely correct, but it will be reasonably stabile which is probably more important. That's why the big, 1 amp, non-regulated power supply is commonly being sold as an upgrade.
« Last Edit: 24 Jun 2008, 05:19 pm by royphil345 »
sts9fan
« Reply #18 on: 24 Jun 2008, 01:41 pm »
So Goodwin's is totally trying to hook me (with good results).  They lent me a Musical Surroundings Phonomana II(sp) msrp $600.  The thing sounds real sweet.  This TT was a surprise and I have my audio budget focused elsewhere so I will not be buying it.  I think I am gonna go to Spearit tonight and grab the Cambridge. Honestly how can I buy a $600 phono stage when I currently own 3 LPs?
TheChairGuy
« Reply #19 on: 24 Jun 2008, 01:58 pm »
Albums multiply quickly with a visit or three to some used record joints.....I lay down $50 and typically walk away with 12 or more.  It's a rather affordable indulgence because of 40 good years of used out there  :thumb:
So, that $600 may well be amortized over more albums than you think right now.
I owned the Phenomena....it's very versatile and sounds just fine.
John
