0 Members and 1 Guest are viewing this topic. Read 11052 times.
The only downside is it's not as pretty as the Trend...Here's a link to the Pop Pulse if anyone is interested http://www.cryo-parts.com/pclink.html
Oops, if I knew it was you that took the photo, I'd have kept the comment to myself BTW, I just placed an order for one of your USB to SPDIF converter
Quote from: PurplePanties on 15 Jun 2008, 08:12 pmThe only downside is it's not as pretty as the Trend...Here's a link to the Pop Pulse if anyone is interested http://www.cryo-parts.com/pclink.html I am a terrible photographer. It actually looks nicer than my awful photo's make it look. One would never say it was pretty though... It's very utilitarian! I'll try and snap some better pics of it soon.Peace, Lee
Quote from: cryoparts on 15 Jun 2008, 08:40 pmQuote from: PurplePanties on 15 Jun 2008, 08:12 pmThe only downside is it's not as pretty as the Trend...Here's a link to the Pop Pulse if anyone is interested http://www.cryo-parts.com/pclink.html I am a terrible photographer. It actually looks nicer than my awful photo's make it look. One would never say it was pretty though... It's very utilitarian! I'll try and snap some better pics of it soon.Peace, LeeHey! Your background is fine. You just need a softer lighting Take care,Buddy
Quote from: SET Man on 22 Jun 2008, 06:49 pmQuote from: cryoparts on 15 Jun 2008, 08:40 pmQuote from: PurplePanties on 15 Jun 2008, 08:12 pmThe only downside is it's not as pretty as the Trend...Here's a link to the Pop Pulse if anyone is interested http://www.cryo-parts.com/pclink.html I am a terrible photographer. It actually looks nicer than my awful photo's make it look. One would never say it was pretty though... It's very utilitarian! I'll try and snap some better pics of it soon.Peace, LeeHey! Your background is fine. You just need a softer lighting Take care,Buddy Sweet, thanks. I'll try and throw a couple of ripped up sheets over the lights to soften and diffuse them.Lee
Or maybe just cryo the lightbulb,,,,,
Well, my Pulse USB to SPDIF have arrived and it's very good. I have it connected to my media centre via Coaxial input with the output to 2 DACs and it sounds very good The photo from the Cryo doesn't really do it justice at all, the unit is really well made and feels very solid. The design is geared towards the unit being functional rather than aesthetic It actually reminds me of the Audio Alchemy products from a few years ago, and we all know how good they were
How does it sound? Does it diminish the sound in any way of a connected DAC of very high quality?What DAC are you using it with? I'm looking for a good DAC of a reasonable price and was thinking I'd go with USB, but this product may allow many more choices if it does not alter the sound in any way.
Quote from: bbaker6212 on 24 Jul 2008, 05:25 amHow does it sound? Does it diminish the sound in any way of a connected DAC of very high quality?What DAC are you using it with? I'm looking for a good DAC of a reasonable price and was thinking I'd go with USB, but this product may allow many more choices if it does not alter the sound in any way.I think you're better off with a USB DAC that does not convert to spdif. I currently have a Trends UD10 and Audio Alchemy DTI/XDP setup with an Audio Magic silver I2S cable connecting the two. It sounds good, but a simple 1 box solution would be nice, and I can't help but think it'll sound better as it skips an entire component and conversion process. So far I'm leaning towards building an Audio Sector USB DAC that'll set me back less than $400, based on many reviews here... haven't heard one yet though.
Is your Trends a UD 10 or the upgraded UD 10.1? What music player are you using? What is your setup, windows, apple, etc? Are you using Asio/asioforall with your player? Do you have an upgraded power supply for your Trends? FWIW, I use a Trends UD10.1 w/Channel Island VDC-SB power supply w/Bolder Nitro DC cable. I run the Trends as a transport on my Windows XP using a Crystal Cable Digit cable to my Sunfire TG4 processor and my audio is excellent. Well it was excellent til I replaced the Kimber USB cable with a Locus Design Axis cable. Now my audio is stellar. I will say that using Asio/asioforall with my J.River Media Center is big,,,, really really big. Cheers,Robin
Quote from: satfrat on 30 Oct 2008, 01:06 amIs your Trends a UD 10 or the upgraded UD 10.1? What music player are you using? What is your setup, windows, apple, etc? Are you using Asio/asioforall with your player? Do you have an upgraded power supply for your Trends? FWIW, I use a Trends UD10.1 w/Channel Island VDC-SB power supply w/Bolder Nitro DC cable. I run the Trends as a transport on my Windows XP using a Crystal Cable Digit cable to my Sunfire TG4 processor and my audio is excellent. Well it was excellent til I replaced the Kimber USB cable with a Locus Design Axis cable. Now my audio is stellar. I will say that using Asio/asioforall with my J.River Media Center is big,,,, really really big. Cheers,RobinJeez, wouldn't it be nice to replace all that crap with 1 simple USB cable? Yes, its the 10.1... I am running a grossly oversized linear regulated power supply with it. Generic USB cable, DH Labs D-75 BNC to RCA spdif cable.Foobar w/ ASIO4All as the player.
Gee, i'm surprised you're not happy...Cheers,Robin
