0 Members and 1 Guest are viewing this topic. Read 15785 times.
Nice !Why did you make the baffle start above the floor instead of from the floor ?Gastón
Hi TonyInteresting. Give us your assessment of what it sounds like to you, your ears, room, system, etc. I think Spruce and Balsa stringers are the way to go for a more complex baffle design. "Sympathetic resonances" is what is attributed to the use of Spruce, in the sounding board of most pianos.
Tony,What kind of material is the phase plug? Do your speakers sound little bright in the top end before or after installing phase plugs? Did you insert the phase plugs all the way in? Thanks,Tan
hi AudiotoneIt has been some time now. You still have the B200?
hican you hear a transparency difference between B200 and Saba green cones?
Hi Tony,How are you keeping.I notice you are experimenting with the B200 at the moment.What effect does the phase plug have on the sound quality?RegardsPaul
maybe you can use spruce and coat it with a sound absorbing material. the thin layer means only higher freqs will be "absorb" a bit
