0 Members and 1 Guest are viewing this topic. Read 33264 times.
i would start w/this, & upgrade it as funds allow. 2bigears, in your case, you could get all the upgrades now! won't sound too shabby as-is... $650 w/no arm:http://cls.audiogon.com/cgi-bin/cls.pl?anlgtabl&1219156969doug s.
We also found out that the 1200, when close attention was payed to setupwas capable of a lot more sound than we intially thought, again showingwhat a bargain this deck truly is. It's just that most people aren't going togo buy 1000 dollars worth of test equipment to dial in a 300 dollar table.But if you already have this stuff around, much more can be pulled outof this humble deck, as you can with the rega p3. These two are probablythe best bang for the buck tables on the market today....Well, that's the results of two weeks of screwing around in my life...
No problem.What I'm trying to say (and I think I'm failing at it..)is that the SL1200 is an excellent turntable and an excellent value.What I see so much in this world of ours is that peoplewant to believe that what they have is the "best" and especiallybetter than what someone else spent more money on.My job is to investigate everything and the hardest part isto put a value on what this stuff costs. I got some biggrenades launched at me last issue, (especially by the mfr) for saying I didn't feel the 56 thousand dollar continuumwas not worth the money.If you are like Wayner and many others that say you areextremely happy with your LP setup, no matter what thecost, I say stop there!I know my advertisers don't like it when I say that, butseriously, I've spent years of agonizing over this stuff and if you've got something that is working great, have a drink and stop worrying about gear!!There have been too many times that I've had a systemright at that point and tried to get more only to miss themark, or merely get different instead of better.Again, you have to remember my perspective is toinvestigate and quantify things as much as we can.So if you ask me "Is the SL1200 a great table and agreat value?" I'll say yes every time.And thanks to the interaction with the people out here,I used to be someone that used to turn their nose upat a 1200 (even though it was my first table, many years ago).But after seeing the enthusiasm here, it made me andour other writer Marc Phillips get 1200's and play with them. Now that we have one in regular rotation, it's veryeasy to compare it to something else and there have beenmany times that I've recommended a 1200 over a P3.It's all about finding the right gear for YOU, not me.So I hope this makes some sense. This is one of the mainreasons I hang out here. I'm always intrigued with what'sgetting a lot of buzz. Some of it I agree with, some of itI don't, but that's what makes this fun!
Quote from: lazydays on 20 Jun 2008, 05:29 amsetup right the P9 will smoke the Technics anyday of the week!! And twice on Sunday!garyin your opinion? in my opinion that might be true - if the technics were not "set up right"... doug s.
Quote from: doug s. on 20 Jun 2008, 11:51 amQuote from: lazydays on 20 Jun 2008, 05:29 amsetup right the P9 will smoke the Technics anyday of the week!! And twice on Sunday!garyin your opinion? in my opinion that might be true - if the technics were not "set up right"... doug s.you might tell that to some folks, but I know the difference cause I've owned two of them. And there are still a couple laying around in the family. If you just gotta have a direct table, then look for a good Micro Seiki.gary
Thanks Tonepub that really hit the nail on the head merely get different instead of better. this so so true when your system reaches a certain point. I keep looking at turntables and waffeling about what price point i should jump into and i'm beging to think you and the chair guy are going to talk me right into a kbmod 1200ed
TONEPUB,I think we are on the same page, but I want to make my point a little clearer. I don't think my tables are the best out there, nor am I completely satisfied with their performance. I can appreciate the VPI Black Knight or a P9 or a high end Nottingham or Oracle, Linn or Basis there are so many out there. My goal is to understand the geometry of all of these machines and dissect them and digest them until I understand them completely. I'm, shall we say, working from the bottom up. Through tweaking, I have a least 5 completely different tables sounding almost the same. That means I'm either doing something right or I'm really lucky. I don't believe in luck.I do have some plans to build a table. With the help of some of my friends, I have high hopes in dialing the tolerances to .00001", to a Baerwald perfect alignment. I doubt it has been done yet. While platter weight, speed stability, outboard vibration influences all have a role in proper (or skewed) playback of vinyl, I believe that cartridge alignment and position relative to pivot are ultra-critical. It's like playing with your speakers, moving the toe angle in or out, tipping them up or a little down, then suddenly, the sound stage opens up so wide you could crawl right in. That is what I want.As time and fashion are starting to prove, There is a tremendous amount of information on a groove of vinyl. I think in the early days they had no idea. I think one of the major reasons for vinyls' comeback (to some never left) is a way better cartridge and stylus that is affordable.As all of us learn from each other about various tweaks and alignment procedures, we are advancing as a group. I've learned alot from this forum from quite a few and I hope they can say the same for me. I always come down to one small problem with the high dollar machine. CAN YOU HANDLE IT? Can you set it up with confidence, or surely what a waste of time.Wayner
No problem.What I'm trying to say (and I think I'm failing at it..).......
We started with the SL1200 and worked our way up to a Rega P3-24,a VPI Scoutmaster, an Oracle Delphi V, the SOTA Nova, Rega P9,SME 10 and then the Raven Two. In the middle of things I had a friendbring over a 1200 with most of the KAB mods.Again the 1200 is incredibly good for the price, but just like the P3,only offers up the basics when it comes to true high end sound reproduction.If I had to compare it, I would compare the SL1200 to the Vandersteen 2Cein the sense that it does give you a ton of sound for a very reasonable price.However, the nuances that are available in the big bucks stuff is not there.That doesn't mean the SL1200 isn't a great deal, it is. And there are a lotof happy 1200 (and Vandersteen) customers out there.We also found out that the 1200, when close attention was payed to setupwas capable of a lot more sound than we intially thought, again showingwhat a bargain this deck truly is. It's just that most people aren't going togo buy 1000 dollars worth of test equipment to dial in a 300 dollar table.But if you already have this stuff around, much more can be pulled outof this humble deck, as you can with the rega p3. These two are probablythe best bang for the buck tables on the market today....Well, that's the results of two weeks of screwing around in my life...
But it's like sittin' in my underware
