0 Members and 1 Guest are viewing this topic. Read 33253 times.
Quote from: TONEPUB on 18 Jun 2008, 09:09 pmAnd I don't mean to be disrespectful to our host the Chair Guy, but the diff between a tablein this league and an SL-1200 is like going from a Toyota Corolla to a Formula One car.It doesn't mean the SL-1200 is not worthwhile, it's probably the best turntable value out theretoday. If carefully setup can do amazing things. But if you have a system capable of theresolution that one of these tables can offer and you also have a pretty good recordcollection, you will not be disappointed.No disrespect felt, Jeff...rock on Candor and free form discussion about vinyl with politeness appropriate between relative strangers is all my fellow co-Fac Larry Crim and I can reasonably ask for.Besides, I'm not by any means a staunch fanboy of the Technics...my co-Fac would fit that bill closer I just bought my 'next' TT today....a fully refurbed DUAL 701 in a new (heavier lumber) base. I was talked out of the 1229 Idler by Bill at FixMyDual as he said his preference over all others is the 701. DC, Direct Drive (not quartz), 9 lb platter and semi-auto function sound worthy of $450.00 to me. The guy is an expert at DUAL's of the 60-early 80's. The 701 is homely, but may work better than it's cover may suggest: John
Quote from: BobRex on 18 Jun 2008, 02:50 pmQuote from: lazydays on 18 Jun 2008, 06:14 amI currently own three tables and gave away a Technics direct drive awhile back. Even the suspension on the direct drive was somewhat ridgid and the other three are non-suspended. What I've found thru the years is that one needs to isolate that table as best he can. So far the best I've found is a Ginko Cloud by a wide margin. Now with this in mind lets get back to the Sotas a minute. We all know they're a good quality table, but many of us don't realize that they have a very well designed suspension system. This makes the bass have a nice warm sound. It's pretty hard to get that out of a non-suspended table or even a direct drive. Dollar for dollar the best buy right now is the Marantz. I personally don't like the drive belts that VPI uses, and will never own another direct drive again. With that being said I do like most of the build quality of a VPI table. Now I've spent enough money thru the years on tables to buy a Sota Millenium with the vac option. For drive belts, I prefer string drives made from something that won't stretch (I currently am using a Kevlar / silk thread). But even now I have at least one or two more tricks up my sleeve.garyOut of curiosity, what have you compared the Ginko to? To me the Silent Running platforms appear to be a more elegant solution, they at least offer levelling. They can also be cheaper than the Ginkos.So instead of string drives, have you considered mag tape ala Teres and Galibier? Or, even the rim drive that VPI and Teres are now offering. At this point my next table short list is the Sota Cosmos, Teres 265 w/ Verus drive, or the smaller TW table. If i go with the Teres or TW I'll probably also get a Silent Running base for added isolation. I've convinced my wife that it's time for a new table, so I should have something by the end of the year.here's the list:* a stock Atlantis rack (short one)* standard steel pucks under the table* brass pucks (slightly better)* copper inert tungstin pucks (best I've found)* solid copper pucks (not much difference between the above and this one* ball bearing pucks with both steel and ceramic balls (not as good as the tungstin pucks)* all the above pucks setting atop slabs of balsa wood (maybe a slight improvment yet)* Big Rock ( was OK, but became a P.I.A. to level it all out and keep the motor aligned)* hard maple (not as good as the Rock or the Cloud)* Ginko Cloud * with standard steel pucks (better than all of the above * with tungstin pucks (not too much difference * beech wood plates under the pucks (noticably better, but not a huge improvment) * isolated the motor base * brass plates (maybe a tiny bit better) * aluminum plates (not as good) * Sorbathane slab (really noticed a difference, and actually made the Denon D103 sound OK)Also did some experiments with drive strings (they all are not the same). There were some noticable improvments here.Next experiment will be to isolate the cartridge from the tone arm, and yet not change the tone arm mass too much if any.gary
to my delight,my NEXT -TT will be a "Rega- P9",price was right,used but new condition.just needs a cart and not really sure what to load it with??.will face this tt off with the Technics 1210M5G.i gotta try this table as it comes with a nice price.the Raven i was lookin' at is 6k,2k for a good used arm and a k note for a good cart adds up faster than a blink of an eye.10,000.00 bucks is crazy money,kinda breaks the bank.the Rega has not a bad rep,good reviews on the most part.we will see
sideways is not what i want to hear . the P9 sells for about 6 times the money the 1210 goes for.this can't be right.i quess it will be a shoot-out for a poor boy that just can't see spending 10 large on a deck.that Rega has to do something right ??
setup right the P9 will smoke the Technics anyday of the week!! And twice on Sunday!gary
Quote from: 2bigears on 20 Jun 2008, 01:16 am sideways is not what i want to hear . the P9 sells for about 6 times the money the 1210 goes for.this can't be right.i quess it will be a shoot-out for a poor boy that just can't see spending 10 large on a deck.that Rega has to do something right ?? setup right the P9 will smoke the Technics anyday of the week!! And twice on Sunday!gary
