0 Members and 1 Guest are viewing this topic. Read 20336 times.
I have been going back and forth between a Black Sand Silver Ref Mk V and a Black Sand Violet II.George
Quote from: zybar on 8 Jul 2008, 02:31 amI have been going back and forth between a Black Sand Silver Ref Mk V and a Black Sand Violet II.George George,Do you have a ModWright Transporter?
So my Spectron Musician III SE amp should be showing up the end of the week. I plan on moving my LessLoss PC from the Transporter to the Spectron as I think that will be a good fit. I have a Black Sands Violet I could use on the TP? But I am totally open to other suggestions as well.
Ted, David (and whomever), the Violet ZIIs are much better than the ZIs and replaced AirSines in my system (only wish I could afford more of them). My ZIIs have the ATL Gold connectors; my ZIs have Oyaide and Furutech Gold connectors. I haven't been able to write a detailed comparison yet because a lot of gear has been going through my system.George, what are your thoughts on the ZIIs?
When did the ZII's come out? My Violet is probably less than 3 months old...Ted, that is crazy! Wierd the way things work sometimes I guess that is the combo I will start with then.
FWIW, I find Rhodium to be very forward and to add a "glaze" to the sound. This experience has held with PCs, ICs, Spkr. cables and outlets. YMMV.
Quote from: rpf on 8 Jul 2008, 03:53 amTed, David (and whomever), the Violet ZIIs are much better than the ZIs and replaced AirSines in my system (only wish I could afford more of them). My ZIIs have the ATL Gold connectors; my ZIs have Oyaide and Furutech Gold connectors. I haven't been able to write a detailed comparison yet because a lot of gear has been going through my system.George, what are your thoughts on the ZIIs? Mine is a prototype and I will need to check back with John on how close it is to the "current" ZII.George
Geez George, I was all set to try out the new ZII till you go and say something like that
