Audio system subwoofer cable options? I like Silver....
0 Members and 1 Guest are viewing this topic. Read 1427 times.
low.pfile
Working on better integrating my Abyss subwoofer into my 2 channel music system. The sub will be covering ~ 40Hz-20Hz range. Along with the dedicated cables, I will possibly try using inline high pass filters (Harrison Labs) for the main down the road.
My question here is any recommendations on subwoofer cable types as I want a dedicated cable from Pre-to the sub. Currently swapping the cable back and forth from my AVRreceiver. I am thinking that a Silver cable may be better due to speed.
Sub specific cables I am considering:
  • bluejeans cable:                    Copper Solid-core   12 pF/ft capacitance.  7ft                      $20
  • cobalt cable:                         Copper Stranded-core         17 pF/ft capacitance.   6.5ft                 $50
  • bettercables silver serpent:    Copper Stranded-core w/ silver coating  <17 pF/ft cap.  6.5ft      $45
All above are shielded
All above are 75-Ohm impedance
Budget is $100
Likely will get a pair of cables instead of my original idea of a Y splitter. The sub has L/R inputs.
BTW: Currently using a single monoprice 6ft coaxial 75-Ohm RCA Cable @ $4.00 for AV use.
thanks, ed
« Last Edit: 25 May 2008, 12:40 am by low.pfile »
dcktr
Re: Audio system subwoofer cable options? I like Silver....
« Reply #1 on: 24 May 2008, 12:14 am »
Blue Jeans is fine and a great value, it is a sub cable.
musicman06
« Reply #2 on: 25 May 2008, 03:21 am »
Your sub won't care, and you won't notice, so just get the cheapest one... which you already have.  :wink:
Trust me bass isn't that fast.  :P
reflex
    • Look & Listen Mobile, Alabama
« Reply #3 on: 25 May 2008, 01:14 pm »
I made my pair.  Very simple to do if you can solder and you have precise control over the length needed.  I used some West Penn 25815 75ohm coax (teflon dialectric) and some decent rca's.  Great definition, speed and body.
As was pointed out...your sub won't care all that much.
low.pfile
« Reply #4 on: 28 May 2008, 06:53 am »
^^Can't solder. Want to though.
Went with Blue Jeans. Length needed is longer than first estimated.  And I directed monies toward a VH Flavor 4 PC and some VH source ICs instead.
Anyone looking for a tons of subwoofer oriented cables check out The Cable Company: http://www.thecableco.com/index.php
cheers, ed
Brown
« Reply #5 on: 28 May 2008, 01:27 pm »
Solid core seems to work well with bass. Blue Jeans will ne just fine.
