0 Members and 1 Guest are viewing this topic. Read 6999 times.
You may need this, a DC trap?
If the filter capacitors are indeed 40uf (which is a very low amount of capacitance for filter capacitors) then 68,000uf is WAY to big. Do you mean 40,000uf? (same as mfd)
Jack,Another DIY alternative: http://www.audiocircle.com/index.php?topic=50908.10Also see here: http://diyparadise.com/dablok.htmlMike
You can increase the capacitance from 40,000uf to 68,000uf with no problem. However, if you are going from 120VDC to 100VDC caps, you might be cutting the margin of safety too low on the voltage rating of the caps. (I can't say for sure as I don't know the details of your amplifier.) As a general rule I would NOT recommend replacing your present P/S caps with lower voltage caps unless you know exactly what you are doing. -- Chris
Hmm... looking at the main circuit schematic there are a pair of 47uF/100V caps on each rail to ground. You originally said 40mfd and the revised it to 40,000uF. Not sure if these are the same ones but I don't see anything that needs a 120V cap based on voltage. mike
