Picked up a Tempest!
0 Members and 1 Guest are viewing this topic. Read 12978 times.
Rocket
Re: Picked up a Tempest!
« Reply #20 on: 20 Jan 2008, 10:53 am »
Hi,
You may have a ground loop problem in your system.  There a lots of potential causes.  Try moving rca's, cheater plugs and it could even be your cartridge etc.  After 2 years I found the problem that was causing hum and it turned out to be that the cdp in standby mode was causing the ground loop problem in my system.  I now turn the cdp off at the mains and I have almost no hum except if I put my ear right next to the speaker cone.
Good luck.
Regards
Rod
Eduardo AAVM
« Reply #21 on: 20 Jan 2008, 08:13 pm »
You can try an Isolation transformer...
TjMV3
« Reply #22 on: 20 Jan 2008, 08:21 pm »
The Tempest sure is sensitive and vulnerable to a wealth of hum and noise influences.
Seems like it never ends with this pre amp.  Shame,  because when it's going good it is a real nice sounding pre.
Haoleb
« Reply #23 on: 20 Jan 2008, 08:51 pm »
I would actually kinda like to get a big isolation transformer I could run all my stuff off of. Big $$ though :(
Haoleb
« Reply #24 on: 26 Jan 2008, 08:54 am »
Well I figure that since I have been trying every logical thing i can think of to pinpoint the tempest's hum issues heres some more things to add to the list of "didnt work".
I have been looking at those devices on the market that filter out DC on the AC mains, such as the PS audio humbuster etc. Found a bunch of different schematics on DIY audio forums but one in particular was easy to follow and looked like it was a winner so I decided to give it a try. The commercially available ones are about $300 so if it didnt work I would at least have to send it back during the 30day guarantee. But if it did work I would be out $300 bucks I didnt have!  :duh: So DIY it was. Ordered parts, scrounged around lowes and radioshack for a chassis and built it and nada. it DOES quiet the buzzing transformer a bit. Although I can still hear it humming slightly. So it works, It just didnt fix the hum in the phono stage. I knew it was a long shot but figured it was worth a try. I suppose at this point Im just going to call it quits and admit defeat. At least I have another preamp with a good phono stage in it for the blue moon's when I do actually put on some vinyl but I had hoped to get this baby going full throttle.
The idea behind these DC trap devices is that DC riding on the ac line sends the transformer into saturation and causes it to buzz and hum. So this device filters out the DC on the line to prevent that from happening. Anyway, Here's the schematic I found and a couple pics of the one I built. I ordered the 10A rectifiers like it says in the schematic but I should have just went with 35 or 50 amp ones just for the hell of it. I believe the PS audio one uses 50A rectifiers according to their site.
On a side note, I also ordered some Blue diffused LED's to replace the ones in my Khartagos that are just too bright. These new ones are alot better, they are a dark shade of blue with almost a hint of purple and are about a third as bright as the other ones. Bad news is I will actually have to go outside to get a suntan now.  :lol: Here's the Mouser part number for them if anyone else is interested.
604-WP7104MBD
Rocket
« Reply #25 on: 26 Jan 2008, 09:51 am »
Hi,
I'm sorry you couldn't figure out the problem.  It took me 2 years to sought out the hum problem that I had in my system and I almost gave up on vinyl in the process.
Regards
Rod
Bob A (SD)
« Reply #26 on: 1 Feb 2008, 08:00 am »
  Knock on wood :)   Guess I've just been lucky as my October '03 vintage Tempest continues to plug away without issues.  Although I was satisfied with the MC stage handling my very low output Denon DL-103D and DL-304 carts, I did build and install a CineMag CMQEE-3440A based step up transformer (SUT) which gives a bit more gain over the Tempest's 60dB.
Haoleb
« Reply #27 on: 12 Feb 2008, 03:58 am »
Today I recieved the Tripp Lite Isolation Transformer I bought used off the boards here and was hoping i would be able to report back with my own "News Flash!" saying that It fixed my problem but once again no such luck! No change whatsoever. Trying to get my tempest phono stage working has been a slight obsession for me lately but now I really do give up. What bugs me more than anything is I dont know how to fix it or whats causing it and neither does anyone else. Aggh Damn electronics!
