0 Members and 1 Guest are viewing this topic. Read 13060 times.
I know that the Sony Zeiss lenses are supposed to be very good. But does anyone have any thoughts about the quality of Sony's non-Zeiss lenses? I'm looking to buy a DSLR and I'm considering the Sony A350 ... am wondering if the standard lenses that come with it are any good, or if I should get the body-only plus the Zeiss lens. The price difference is pretty huge (for $1099, you can get the A350 plus two non-Zeiss zoom lenses, or the body-only plus Zeiss (16-80/f3.5-4.5) for about $1500)...and this would be my first DSLR, upgrading from a Canon S2 IS superzoom point/shoot. Thoughts?
Over the years, I've been a big Canon fan for their point-and-shoots, but Buddy/SETMan got me thinking about the Sonys for the DSLR. They seem to have a lot of things going for them in terms of usability over the Canons (according to a few reviews I've read), particularly the live view and autofocus quality. As far as Nikon goes, it's a possibility although I hear a lot more praise for their top-of-the-line cameras and not so much for their entry-level to intermediate DSLRs.Anyways, I'm still probably a few weeks away from making the purchase, so I'm still investigating options...
.....Canons and Nikons have dominated the market....
...but Buddy/SETMan got me thinking about the Sonys for the DSLR.
... Just ask Buddy 'cos he has a Sony.
Phil, if you feel that having Canon or Nikon around your neck will give you better photos and make you take better photos than go for it.
Quote from: SET Man on 16 May 2008, 09:41 pm Phil, if you feel that having Canon or Nikon around your neck will give you better photos and make you take better photos than go for it. But here's the thing...I don't have a feel at all for which of these will give better photos...that's why I'm asking. I understand that lens quality is hugely important, so I posted this mainly to get a feel of how the non-Zeiss Sony lenses stacked up against the Zeiss lenses (my understanding is that the non-Zeiss lenses are pretty much re-badged Minolta Maxxum lenses, which seemed to have a good reputation), because I've got a wife-enforced budget that will make me balance body-vs.-lens spending...I wanted to get a sense of the compromise I would be making going with a non-Zeiss lens which would allow for me going for the A350 (instead of the A200)...
I did read somewhere in a Sony A350 review that the current lineup of Zeiss lenses is somehow "optimized" for digital relative to the old Maxxum lenses. Is this possible? Or is that like audiophiles using "optimal amounts of blue-tak on their monitor stands"?
I don't anticipate buying a lot of lenses...I'm hoping that whatever I initially get will be "it" for a few years (this applies to both lens and body). My expectation is to get something in the 20-80mm range (hopefully f2.8 ). If I did get a second lens, I'd want to get one with a long zoom (200mm minimum).
The 16-80 is not f/2.8...?
Buddy...thanks for the input. And as it turns out, my father-in-law has a bunch of Minolta Maxxum lenses that my brother-in-law bought for him years ago (BIL is really into photography, FIL never uses them)...so I might be getting a bunch of legacy Maxxum lenses.
Zero...I am not a fan of the Sony digicams, but mostly because of the problems I have had using Memory Sticks. And I am not a fan of Nikon digicams, because I think their user-interface is not very intuitive (this is an opinion formed many years ago, so they may have improved since then). I have always liked Canon digicams and have owned 4 (including the S110, S200, S410 and S2 IS).
With regards to DSLR's, tho, Sony acquired Minolta/Konica last year, so much of their lineup comes from technology developed by M/K. So the Sony DSLRs start off with a better reputation than Sony's digicams..
Andrikos...I appreciate the pro angle. But I also think that some things that pros will appreciate will also annoy me. For example, I read somewhere that the Live View function on the Canon XSi, while ultimately more useful for a pro photographer, is actually quite clunky to use. As I am not a pro, the Sony's Live View implementation, while not being as flexible as the Canon's, is supposed to be much easier to use. So in this particular example, the Sony wins. On the other hand, its clear from every review and comparison of the A350 vs. XSi that I've read says that the XSi has a lower-noise sensor...so from this angle, Canon wins. So this is my dilemna....
