0 Members and 4 Guests are viewing this topic. Read 97706 times.
Next question:Any idea for a matching tweeter? I've heard of people using a Fountek ribbon tweeter. Other's claim that ribbons and widebands do not match. What's the deal?Third question:Does the Tubby drivers have an ok bass extension, or is it mandatory with a woofer?Any chance of making a three way system with 1st order crossovers, and not use EQ?
I've measured the T/S for the two TT I have in house and unbroken-in they are pretty close to what is (or was) posted on the A Broun Sound website.Regards,John
Here's a copy of ToneTubby's #s, courtesy of archive.org: http://web.archive.org/web/20060215064937/www.tonetubby.com/specs12a8.htm.The only # missing is Le, and I came up with .177 and .191mH.Regards,John
Fs = 107.32 HzFsa = 52.36 Hz BWs = 12.72 HzWhat is the difference between Fs and Fsa and what is BWs? Is resonance freq. =52.36Hz?
With the high FS and likely very little to no linear excursion (most guitar speakers have no linear excursion), they will not have much bass extension and would probably be best high passed at 2-300 Hz.
I see the 10" driver has a couple dB lower efficiency, so maybe this is easier to couple with an OB woofer? I understand the point of an active woofer though.These compression drivers all have extremely high spl. Aren't there any tweeters that can match the TT without using an L-pad? Any special reasons for choosing compression drivers and horns? Are these known to match well with big widebands?
Thanks, did you perform a freq response curve?
For the 12", I don't know of any non-horn that will work. Also, as you get into this a bit more you'll find that most compression drivers on a CD horn will have just enough sensitivity to match up. That's because on an OB you're looking at ~100dB/1W with the TT 12" and CD horns have a falling response. Typically, 1" compression drivers are up around 107db at 2khz but decline from there to, say for the Beyma CP380M, to 98dB/1W at 16khz. So, no l-pad but instead a notch filter to eq the response.
Otherwise you may want to use Gedlee waveguide, no equalization is required as far as I know. FYI it is not cheap in excess of $150. A cheaper alternative is DDS Eng 1-90, about $99, here no equalization is required as well, I heard good reviews about this horn.
