0 Members and 3 Guests are viewing this topic. Read 97714 times.
Hi Lazz,Certainly one could use just one TT12 and then run the woofers up to 300hz or so, but I decided I'd rather add the second TT12 and get the mains to cover down to 100hz. Just a personal preference, I suppose, no real reason.Regards,John
Why not the 10"? Should extend more on the HF (cant find a graph)...
Quote from: Telstar on 3 Apr 2009, 12:13 amWhy not the 10"? Should extend more on the HF (cant find a graph)...A couple of reasons, I suppose. First, the 12" is more efficient and I really wanted a speaker close to 100db/watt. And, I don't need the midbass to go higher than 1.2khz -- the compression driver I'm using is plenty comfortable playing that low. Really, I'd rather the crossover be lower rather than higher. If I thought I had a chance at getting a 15" driver and a 1.4" compression driver to co-operate and cross over at 700-800hz, I'd have gone that route. Of course, that's a whole nother story...Regards,John
I still need to work on the (sub)woofers. As expected, the mains rolloff around 100-120hz. I have something in place now, but it's not worth discussing. I have a quartet of OB15 from the nice fellows at AE, and I'm looking forward to getting baffles made and the active filtering built up. I already have the boards back from ExpressPCB and components have arrived from Mouser.
I built a prototype to see if I could pull together a fullrange open baffle speaker. It's a 2.5way -- mids and treble are as before, Beyma CP380M + AH!1000 conical horn and ToneTubby 12" AlNiCo. The .5 is now a 4x Eminence Kappa-12A. Initial listening impressions are generally positive, and I'll be pulling out the measurement gear later today.
