0 Members and 1 Guest are viewing this topic. Read 13355 times.
I just installed it and everything is working fine.
The full stand alone version can be had here: http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=enAll 316 megs of it...
Now it will try and launch XP but will not start. It goes back to the beginning where you can access the DOS menu. Any ideas on how to fix it?
Me and my big mouth. I did not realize it right away since I usually turn on my computer and then go do something else while it boots up. But since installing SP3 my computer takes several minutes longer to boot up. Sometimes 5-6 minutes.I have NOT installed any other software recently either prior to or after installing SP3. I ran Norton systemWorks scan and fixed some registry and other errors but that did not seem to help.Thank you Mr. G.
