0 Members and 1 Guest are viewing this topic. Read 18328 times.
Where can I buy that in the US? Madisound shows it as out of stock, and a quick Google search didn't turn up any others.
If I remember correctly Peerless sls 830669, has low spl, other alternatives with high spl areLambda TD12H 12" from AECiare 12.00NdW1 12” from assistance audio, both units have high spl > 92db,
I currently have an Audax PR170M0 (on an OB) and a Fountek JP3.0But if I keep the PR170M0, that means my woofer now needs to go up to 350/400. And I'm not quite sure what that implies... a U/H frame is probably out, since that'll be up in the cavity resonance region, I think.
If you want to build with 1*12" woofer than I think monopole, vented is the way, like J. Bagley's open baffle.
You may want to ask gitarretyp, he uses 4*M165X(7" woofer), about $44 each with Fs=40 and Qts about 0.4. He uses open U-frame he may have some suggestions to get freq low.
Lambda 12TDX...
