0 Members and 1 Guest are viewing this topic. Read 18329 times.
Look at the new GR research woofer, they have a circle here.I just got mine in the mail today - they are certainly the business, and servo controllable this is a subwoofer btw... 15 - 150hz or so
I believe you want to get the freq to go down to that region you need low Fs as well as high Qts>=0.7, if you cannot get qts >=0.7 then you need U or H frame. I also believe you want open baffle bass then you need 2 woofers not one connected in parallel.
the sevo controller is part of the amplifier - woofers are 150 each and servo amp is 279 usd +shipping
Quote from: WerTicus on 19 Jun 2008, 09:44 amthe sevo controller is part of the amplifier - woofers are 150 each and servo amp is 279 usd +shippingThanks, 2 more questions:1. you need 1 amplifier for 2 woofer or 2 amplifiers, i think it is the latter.2. The highest freq., the woofer will x-over
The big problem with OB bass is the crazy rising response - or lack of bass, if you want to look at it that way. So you gotta do something.
I'm currently leaning towards a pair of Dayton RS270's, they look clean up to 500Hz and higher. The high XO also mostly rules out U and H frames, so I'm modeling these on flat baffles to see what I get.
An Audax PR170M0, which has 0.5mm Xmax, and a manufacturer recommended XO of 18dB @ 600Hz. I've used it with LR4 down to about 400Hz on an OB, and it sounds fine, but I don't want to go too much lower than that.http://www.hautparleur.fr/_audax/pr170m0b.jpghttp://www.hautparleur.fr/_audax/pr170m0.jpgIf I upped my budget by a 2-300 bucks and picked up a PHL/B&C/Beyma midrange, then that would probably make the job of finding a woofer a lot easier.I'm not really thinking of the 270s any more. A modified AE IB15 (with reduced mass) is an option, it gets a little ragged by 500Hz, but not really any worse than the Alpha15. It will require more EQ, of course. The Peerless 830669 might work too, but I haven't seen any measurements besides the ones from the manufacturer.
This thread is pretty out of date I have a pair of BMS 4540NDs, and a pair of XT1086's should arrive today. If the threaded/bolt-on mismatch isn't too bad (and it probably will be, which means I'll probably switch to a bolt on CD), then that's what I plan to use. That can go down to say 1500-2000, I think.High efficiency is a goal for the upper panel (mid+tweeter), not the woofers. I'll be running these off a 4W SET, so 90dB isn't enough. 95+ at least, 97+ would be best. The normal choices for 8" woofers/midwoofers won't work, some of the pro ones might.
