0 Members and 1 Guest are viewing this topic. Read 28624 times.
Sterling Duet with Darryl's fine craftsmanship run $3700/pair (plus you need a sub amp of some sort).
I respect Justincaz's opinion, but with all due respect, I disagree.I'm curious as to which version of the crossover you heard, and if the drivers were fresh (new and a bit "tight"), or well broken in?From day one of having a pair of the SI's in a DIY baffle I knew I was on to something special. I was hearing things I'd not heard from CD's I've had for decades and listened to countless times. Baffle size, shape and construction is the 'fine tuning' needed to achieve "personalized" open baffle euphoria. Maybe the baffle was not to Justincaz's liking. Who knows? Maybe it was a "bad" room for OB. We are all sensitive to certain frequencies. Maybe the tubes in use were not flattering? Maybe the owner of the SI's thought things were perfect for his liking, but obviously not to Justincaz's preference.
Quote from: Bob in St. Louis on 9 Jun 2008, 03:11 amI respect Justincaz's opinion, but with all due respect, I disagree.I'm curious as to which version of the crossover you heard, and if the drivers were fresh (new and a bit "tight"), or well broken in?From day one of having a pair of the SI's in a DIY baffle I knew I was on to something special. I was hearing things I'd not heard from CD's I've had for decades and listened to countless times. Baffle size, shape and construction is the 'fine tuning' needed to achieve "personalized" open baffle euphoria. Maybe the baffle was not to Justincaz's liking. Who knows? Maybe it was a "bad" room for OB. We are all sensitive to certain frequencies. Maybe the tubes in use were not flattering? Maybe the owner of the SI's thought things were perfect for his liking, but obviously not to Justincaz's preference.or maybe it was the speakers? every aspect i didnt like about them vanished when a proper design took theyr place. such as B&W, PSB, Dynaudio..and yes, the drivers are fully broken in well over a year now. iv heared them both as brand new and in the recent weeks. they have a fine baffle and we have tried them out thru 4-5 full set combinations of electronics. all the way from cheap cambridge too expensive single ended stuff. me im wondering why the genius of a 15" + 1" design just flew past all speaker manufacturer's on the planet..? is there a reason why noone uses anything larger than 8" for midrange?sure, the silver iris is very good for the price indeed! atleast the drivers by themselves. but the speaker design as a whole is bad(no pun intended). the woofer heavely distorts its upper range, both drivers are to directional and the frequency respons feels like a rollercoaster. the tweeter isnt even level matched to the woofers sensitivity (if so it may be the rising respons of the compression unit itself).. also the tweeter is phase inverted to fix a peak somewhere, this makes the integration with the woofer even worse!im curious about the sterling edition thou, it has a much better compression driver and a crossover freq. witch is much more fitting for a woofer at that size. maybe iv even interested in getting a pair sometime big drivers are fun and pack a punch on deep male voices. but are they going to set the standards for the hifi industry? no, never. if so we would have seen em allover. the only one that comes to mind is Tannoy Glenair 15. and it also has its own kind of audio personality.
The undebatable challenge with the design is transitioning from a 15 inch to a 1 inch set of drivers. That it works at all is rather amazing. I've not heard the 10 inch version and don't quite understand how it reaches as deep as the 15 incher, but it should help alleviate the related issues. I'd really like to hear a Sterling 10 inch coax by itself.
I just got a set of the 10" SI's and love them them! I am definitly crossing my fingers hoping that the 10" Sterlings will be a reality I have a set of Radian 465's I'm debating on trying to tinker with them, But I'm also, waiting for the Stock Eminence tweeters to break in fully.
Thanks for the invite and the info on the 10 inch versus 15 inch bass response. But someone had better fix the Hawthorne website as it states the same Fs.
Its hard to believe more changes weren't made to the woofer...it sounds like a difft beast. Radian tweeter aside, the differences I hear must be your x-over. aa
