0 Members and 1 Guest are viewing this topic. Read 28621 times.
Hi DonThanks so much for the clarification. Do you know if Hawthorne sells the Silver Iris with the radian tweeter as an upgrade, or do you have to buy the sterling edition to get the radian? Just curious, since the sterling is about $600 more than the standard silver, so I thought it might be possible to get at least part way to the sterling without spending quite so much. To switch to the radian, are changes in crossover required? I seem to remember reading somwhere that the radian is a drop-in replacement in the silver iris, but I may be mistaken.Thanks again, I can't wait to start experimenting aaChris
Hi DaveThanks very much for the helpful reply. I know with my current speakers, I thought the tweeter was a bit harsh until I swapped in some Mundorf and Jupiter caps in the tweeter and mid sections of the crossover. Low an behold, the tweeter was not the problem, so your point is well taken. At this point, I think I'll save my money and go for the Sterlings with the upgraded crossovers to get the full benefits.Thanks againChris
