0 Members and 1 Guest are viewing this topic. Read 30725 times.
Bypassing the input card does not result in a phase mismatch at the output in my modifications. Mono/bridged mode is achieved by sending the signal to BOTH CH1 and CH2 inputs, and ground to one of the available input grounds. Both setups have been tested and prove functional and incredibly positive. Both setups have also been tested with a phase tester and maintain absolute polarity from input to output.I hope this helps a bit.Nathan
Nathan, have you been able to apply a signal to R405 or R403 to achieve a direct path to the input of the Tripath module. Also have you figured out how to lower the power supply impedance at the amps switching frequency.
I hate op-amps. Rant deleted.
The modifications discussed so far have been an exercise in trying to eliminate anything between the input setting gain resistors and the input jacks on the back of the amp.
Any of you gents playing with the ZR1600 have an opinion on the pros and cons of adding a tube (6922 or 6DJ8) buffer stage at the input and wiring directly to the tripath chip?
I just noticed that they have been added to the set of schematics on the Carver Professional web site.
