0 Members and 1 Guest are viewing this topic. Read 30730 times.
Any talk of the parts on the output board? This should be easy to bypass, and should provide favorable results.
Which form factor provides the best heat transfer, 220 or 247? I may end up ordering more than I need because of small part quantity prices/shipping/handling.
Monolith, check the Tripath site for their recomendations on inductor core materials and read the application notes on their modules. It is unlikely that Carver deviated from their recomendations on this part. The inductor has to pass instantaneous currents of large magnitude without significantly adding to the output resistance of the amp.An aircore might have lower distortion but it's series resistance can't be any higher than the ferrite cored inductor and it cannot have significant self-capacitance, ...
The previously discussed IXYS diode brigde's pinout and size is problematic, and my 'thin air choice' of individual Fairchild Stealth(tm) rectifiers, requiring assembly of a module and a fabricated heatsink, has its own attendant problems.Its far easier to aquire a common pin and form replacement, such as BRUS3[4]W, made by the same maufacturer, EDI, that supplies the conventional bridge which we seek to replace. http://www.edidiodes.com/PDF/Bridges/BRUS3-4.PDFThis would allow a simple swap, prest ...
I'm doing the 8thNerve mod myself next week and Nathan said nothingabout gain loss, I'm sure he would have if there was. I do know about gain loss when I disconnected the fan.
At present my DIY TRIPATH amp employs no input bandwidth limiting. The input wiring is shielded to reduce RF contamination. The opamps U206A and U207B may help eliminate RF as well as ultrasonic signals from the modules' input. I could not tell you if this is necessary. I think if you can get an uncorrupted signal to the modules' input the amp may sound better.The power supply impedence still needs to be lowered at the amps operational switching frequency. A problem for another day.
