4B-ST with DNM speaker cable
0 Members and 1 Guest are viewing this topic. Read 1967 times.
tcmo
« on: 22 Apr 2008, 02:48 pm »
Will I harm my amp if I use the DNM speaker cable?  It is small gauge (approx 20 ga) constantly spaced solid-core cable.  I'm trying it out and sounds very good, but does it make the amp work "too hard"?   The DNM dealer says it is no problem and he uses it for all his demo speakers.
Thank you.
  • The Demo is Everything!
    • http://www.bryston.com
Re: 4B-ST with DNM speaker cable
« Reply #1 on: 22 Apr 2008, 03:17 pm »
Thank you.
Hi tcmo,
It will not harm the 4B but 20ga is pretty high (thin) so keep the length as short as possible. We typically recommend 12ga and in our studio installations we use 9ga.
james
« Last Edit: 22 Apr 2008, 03:40 pm by James Tanner »
tcmo
« Reply #2 on: 22 Apr 2008, 04:06 pm »
Thank you for the reply.  I am using 6 ft lengths.  I'll use it for a while, then maybe change.  It was an experiment using solid-core speaker wire and it was not that expensive.
« Reply #3 on: 22 Apr 2008, 04:18 pm »
Ok - let me know the results.
james
vegasdave
« Reply #4 on: 24 Apr 2008, 02:52 am »
I use 10 ga Belden in 6 ft. lengths per channel. Is this too long? Also, no need to bi-wire, true?
eril
« Reply #5 on: 24 Apr 2008, 04:46 am »
I used DNM with my Bryston B100 today.
It worked fine.
Sound was mellow - transients and dynamics were reduced - could be good with bright speakers/room.
FWIW
