DACT CT101 line stage module
0 Members and 1 Guest are viewing this topic. Read 3049 times.
cityjim
« on: 18 Apr 2008, 01:57 pm »
Hello all ,
 anyone built this DACT CT101 line stage module yet ? I have some batteries I need to put to use . Looks like a simple design with sensible gain to it .
 http://www.dact.com/html/line_stages.html
cityjim
ehider
Re: DACT CT101 line stage module
« Reply #1 on: 18 Apr 2008, 03:16 pm »
I had one of these a couple years ago and was VERY impressed with it's resolution, speed, transparency and image stability. It does put quite a few transistor pre-amps to absolute shame that are above the $2k mark. Perhaps the simplicity of the circuit is what makes it sound so good? My understanding is that it sells much better in Europe than here in the states.
Kevin Haskins
« Reply #2 on: 18 Apr 2008, 05:55 pm »
Your telling me.    They don't sell well at all in the US.
TomW16
« Reply #3 on: 19 Apr 2008, 03:05 am »
I was interested in the CT101 too as a buffer (zero gain) for my passive preamp but couldn't find much information regarding people's impressions about it.  Kevin, you should have a fire sale and get rid of those circuit boards that are just taking up space.   You might get at least two sales  :wink:
The other one I considered was the Welborne mini-amp.  In the end, however, I am just sitting tight since the impedences between my DAC and amp are so good that I am doubtful that a buffer would help matters much, if at all.
Tom
cityjim
« Reply #4 on: 19 Apr 2008, 11:25 pm »
"Note: We do not keep large volumes of inventory of the Active DACT parts due to low demand. Lead times on these products are often in the 4-6 week time frames."
Kevin , is this true ? 4-6 weeks ? I want to order this but will pass on the 4-6 week status .
cityjim
cityjim
« Reply #5 on: 29 Apr 2008, 06:13 pm »
I just ordered the CT101 line stage module and DACT 10K attenuator . I have a surplus of 12V 17AH batteries that will get a new home . I'm going to give the CT101 a huge dual mono battery power supply . And some fat capacitors to lower the power supply impedance .
 I was looking at the Joshua Tree remote attenuator but is sold out . New design underway . I've been wanting a preamp with no gain (unity) . My current tube preamp has 24db of gain and 24db of noise on top of that . Which is waaaay to much for a CD source . I will let you guys know when I get it all together .
 TomW16 , I found a good price on the DACT CT 101 .  http://www.soundlabsgroup.com.au/c/DACT/DACT.html  . Price was $215 U.S. dollars plus shipping . Plus it was in stock . I received 3 emails confirming shipment and customer satisfaction .
 I almost pulled the trigger on the Prometheus C-core TVC . I'm glad I went with the DACT now . Less wire to have the signal run through . I would love to hear that Promy though . I bet it is sweet with all the rave reviews on the standard models .
cityjim
