Audio/Video Gear and Systems
The Lab
sts9fan
in need of advice
in need of advice
0 Members and 1 Guest are viewing this topic. Read 1271 times.
Derockster
in need of advice
17 Apr 2008, 05:56 pm »
Hi guys I'm having a problem with a diy preamp I recently acquired.The problem is in the phono stage of the preamp.I get maximum output from the left channel and very minute output from the right channel.So much so I have to turn the volume nob almost all the way up and even then I can barely hear anything through the specific channel.I swapped tubes in and out to verify it wasn't a tube going bad but that's the extent of my abilities.Any input as to what's wrong will be greatly appreciated.Regards derockster
JoshK
Re: in need of advice
17 Apr 2008, 07:41 pm »
Sorry to say, but there is nothing we can do to help with so little information to go on.
whubbard
Reply #2 on:
18 Apr 2008, 01:34 am »
What pre-amp are you using...or did you design one yourself? (I doubt the latter though given your situation.)
The Lab
sts9fan
in need of advice
