Signal gauges on tuner reading when powered off
0 Members and 1 Guest are viewing this topic. Read 1233 times.
Steidl Guitars
« on: 16 Apr 2008, 11:32 pm »
I bought a used Dynalab FT-101A tuner recently and it operates fine.
I just noticed, however, that when it is powered off, the signal strength gauges continue to operate as if it is still on; only when I unplug the unit do they flop to zero.
Is that normal?  If not, any idea what the issue might be?
Many thanks!
Bob
JAMn Joe
    • http://www.jamnaudio.com
Re: Signal gauges on tuner reading when powered off
« Reply #1 on: 17 Apr 2008, 01:52 am »
Hi Bob,
My FT101A has been doing it since I bought years ago and the needles are still bouncing. I believe that is the normal operating mode for the needles with the FT101A. The circuitry that passes the signal to the gauges is not disengaged unless AC is removed from the tuner.
As I said, my unit has been doing it for years with no issues.
Steidl Guitars
« Reply #2 on: 17 Apr 2008, 02:44 am »
Joe,
Thank you kindly for your reply.  Now I'll stop fussing over it!
Bob
