FS: VMPS 626R Fully Upgraded in Cherry + Steel Stands
0 Members and 1 Guest are viewing this topic. Read 1397 times.
kowloonside
Chicago-area buyers - these are the ones you're looking for (but I will ship too).  $1500 OBO.  Thanks.
These are simply some of the best monitors available. Incredible detail and clarity combined with the best bass you can get in a monitor design...which is not to say "merely ok" bass. These beauties have a tested F3 of 37Hz (with the included megawoofers) and I personally had in-room response of -3db at 30Hz. This is possible because of the custom Neodymium Ribbon midrange panel that covers from 166Hz to 6.9 MHz and Fast-Swinging Ribbon tweeter that takes care of the rest. That frees up the custom woven carbon-fiber 6.5 inch "megawoofer" that VMPS is famous for to produce low, tight, and clean bass...there is also the fact that these are nearly 2 cubic feet of speaker per cabinet (no replacement for displacement after all). Even better, both the midrange and the tweeter are adjustable so that you can tweak the overall sonic palette to your tastes and your room - you'll never have to worry about laser precision that could fatigue you or a dark, veiled sound that makes you wonder what details you're missing. Simply find your "sweet spot" and enjoy the music. Speaking of sweet spots, VMPS pioneered (and patented) the constant directivity waveguide. This expands the sweet spot into a very large sweet zone - no more "beaming" from ribbons. That incredibly wide midrange also means that you get the critical midrange where 80% of the music is completely uninhibited by any crossover.
Full specs from the manufacturer:
Bass: - 6.5" WCF Megawoofer bass, rear reflex loaded
Mid: - rectangular 10 x 20 cm (4 x 8") Neo ribbon, 166 Hz - 6.9 kHz
Treble: - FST, 6.9 kHz - 30 kHz
Impedance & Sensitivity: - 8 Ohm (5.6 min.) 90 dB/1W/1m
Power handling: - 150 W rms /4 Ohms, 20 W min.
Frequency response: - 37 Hz-25 kHz +0/-3 dB
Dimensions & Weight: - 61H x 25W x 33D cm, 18 kg (24"H x 10"W x 13"D, 40 lbs)
Output levels and distortion: - max. 1% THD fullrange / 1 W, max. 110+ dB SPL / 1 m
The VMPS website also has a lot of great information on their design principles, including why carbon-fiber is the best material for woofers and how they engineer to ridiculously tight tolerances. For reviews, positive feedback reviewed them not once but twice! You can find them with a quick google search (linking is not allowed here).
Here is the full list upgrades of the pair for sale, along with the price of each:
FST (ribbon tweeter) - $400
TRT capacitors - $1200
Megawoofers (last generation) - $200
Soundcoat - $150
Constant Directivity Waveguide (piano black)
Cherry cabinets
With these upgrades, the speakers are worth over $3000 new.
They are in flawless condition and come from a kid / pet / smoke-free home. There is a 1-inch scuff on one of the waveguides that is only visible when the light hits it the right way...not a scratch mind you, just a scuff. I also have the original fabric grills. I do not have the original box but will overpack them for safe shipping (including covering the tweeter to protect the ribbon). Pictures available upon request.
Finally, I have a pair of custom black steel stands with a floating plate design. They are 23-24 inches tall, customized with the adjustable spikes. These are amazing stands that cost over $600 - I can include them for $200 if you are alright paying the shipping for them as well. They are about 50 lbs each. Of course local pickup would be best for the speakers and / or stands.
« Last Edit: 9 Apr 2008, 01:19 am by kowloonside »
JP78
Re: FS: VMPS 626R Fully Upgraded in Cherry + Steel Stands
« Reply #1 on: 10 Apr 2008, 01:05 am »
photos?  those are too good to post without pics! :)
