Emerald Physics CS2 connection question
0 Members and 1 Guest are viewing this topic. Read 1202 times.
mca
« on: 2 Apr 2008, 11:30 pm »
After trying a couple of speakers that have not worked out, I am back to wanting to try a pair of CS2's. The complexity of these speakers does bring up one problem for me. I am using the same pair of speakers with separate music and movie systems. When I want to listen to music, I just unplug the speaker cables that go to my Onkyo SR805 and plug in the speaker cables from my RM-200. Kind of a pain but that's what I have to do. If I try a pair of CS2's, I would probably look for a RM-10 to power the tweeter. I don't really want to have to use the tube amps when watching a movie. Is there any work around for this?
miklorsmith
Re: Emerald Physics CS2 connection question
« Reply #1 on: 2 Apr 2008, 11:34 pm »
Are your hemps for sale?
mca
« Reply #2 on: 3 Apr 2008, 06:05 pm »
After reading this, I may take the full plunge, amps and all. Add a Modwright or other tubed pre with HT bypass and I could be all setup for music and movies with just the flick of a switch.
http://6moons.com/industryfeatures/secondcoming/secondcoming.html
John Casler
« Reply #3 on: 3 Apr 2008, 07:20 pm »
Are you not able to take the L&R (mains) analog output of the SR805 to a L&R analog input of your 2 channel Preamp for HT?  Or are you not using a Preamp?
That (if possible) would eliminate having to change speaker cables and you would use your 2 channel amp for both HT and 2 channel audio
mca
« Reply #4 on: 3 Apr 2008, 07:38 pm »
I am not using a preamp as I am feeding my SB3 directly to my amp. Since the CS2's require four channels of power, this still would not work.
John Casler
« Reply #5 on: 3 Apr 2008, 08:02 pm »
Got it.
