0 Members and 1 Guest are viewing this topic. Read 3626 times.
Doesn't this work? (the brightness button)http://wiki.slimdevices.com/index.cgi?AutomaticFirmwareUpgradeI've also had to initially connect the SB to the server using no encryption, establish a link, then go back and use the encryption. That let the SB see my server every time after that. Don't know if that helps you.
Sometimes the IP addresses jump around if you have automatically set DHCP. Push the left arrow until it goes back to network selection, Scroll down to see if there is a new IP address listed. Then use the new one.
I know about the brightness button, but I can't upgrade the firmware via the computer if I can't establish a connection. Further, I don't know where to find firmware v88, or where to put it on my computer once I do find it. From what I've been able to gather today, until the firmware v88 is loaded, the SB will not connect, period.
Quote from: Double Ugly on 31 Mar 2008, 02:04 amI know about the brightness button, but I can't upgrade the firmware via the computer if I can't establish a connection. Further, I don't know where to find firmware v88, or where to put it on my computer once I do find it. From what I've been able to gather today, until the firmware v88 is loaded, the SB will not connect, period.Can you hook up the SB directly to the computer via Ethernet just to do the firmware upgrade?
Haven't tried yet, primarily because I doubt it'll work, but also because I can't update what I don't have. I spent a little more time on the SD forum last night, and I think only one person managed to get the wired connection to work. Several others tried, but failed.
There are lots of people who run their SB via a wired ethernet connection directly from their computer, aren't there?
Also, does your broadband router have built-in ethernet ports? You can hook your SB into that via wired/ethernet to do the firmware upgrade, right?
