RIPPER Hum Reduction
0 Members and 1 Guest are viewing this topic. Read 1765 times.
hagtech
« on: 26 Mar 2008, 11:37 pm »
I worked out a better wiring scheme for the RIPPER phono input.  I cuts the hum levels a bit.  You just have to install some resistors in a wierd way:
First install the 47k input resistors R34 from their input holes to the common big ground hole in front of the IC.  The do the same thing for the 316 ohm R27 gain setting resistors.  It looks funny, but does make an audible improvement.
jh
Brinkman
Re: RIPPER Hum Reduction
« Reply #1 on: 27 Mar 2008, 12:38 am »
I just knew there was a reason I was taking three months to build my Ripper! :wink:
Thanks for the mod, Jim.
-Brinkman
PatOMalley
  • This text is personal
    • http://home.comcast.net/~omaille/audio/home.html
« Reply #2 on: 27 Mar 2008, 12:13 pm »
Would this work for the bugle as well?
hagtech
« Reply #3 on: 27 Mar 2008, 06:27 pm »
No, there are no ac power supply currents on the board.
jh
Aljaheejus
« Reply #4 on: 26 Aug 2009, 03:35 am »
Since I'll have mine open again, I may just do this mod.  Any reason not to?
Also, can you clarify that the R27s are connecting their output to the ground, while the R34s are connecting their input to the same ground?
hagtech
« Reply #5 on: 29 Aug 2009, 10:59 pm »
Any reason not to?
This is a good mod.
jh
