Poltergeist in my turntable
0 Members and 1 Guest are viewing this topic. Read 897 times.
jono2channel
« on: 26 Mar 2008, 10:11 pm »
 :scratch: I have an AN TT-1 and I love it. I just upgraded my pre amp to the new Rotel RC-1082. It is much quieter than my old one. The thing is now just as I am about to spin a record, I pick the tonearm off its rest, and it begins a quiet buzz...or hum. If I put it back down it is quieter. Up...humm...down....quiet.  At this point I haven't even touched the needle to the record.  The only way that I can get it to stop completely is to lift the head of the tonearm straight up until it bumps against its stopping point. Then it is silent. :x I dream of quiet playback, but this is just enough noise to be heard when I listen.  :duh: I know that this gets a lot of chatter around here. I searched the archives and found nothing of turntable poltergeists. What do you all think?
Wayner
Re: Poltergeist in my turntable
« Reply #1 on: 26 Mar 2008, 10:23 pm »
Sounds like your tonearm is ungrounded or becoming ungrounded when you lift it off the post. Perhaps a continuity check is in order. See if you have a circuit from tonearm metal to ground screw in both conditions
Wayner
