0 Members and 1 Guest are viewing this topic. Read 33844 times.
Art or anyone esle,Is money better spent on a new linear power supply or on digital upgrades for the Duet.(I use my Duet, digital out to my dac)Thanks,Bill
Quote from: mr_bill on 3 Aug 2008, 10:20 pmArt or anyone esle,Is money better spent on a new linear power supply or on digital upgrades for the Duet.(I use my Duet, digital out to my dac)Thanks,BillIMO, digital output upgrades make a much bigger improve than spending lots money on a linear PSU.If you want to upgrade the Duet receiver''s PSU to a linear, here's one:Acopian -B9G50. Cost- $100.www.acopian.com/ PS- I read in another thread that Ebony pucks were used in a very expensive PSU. I couldn't fix these pucks into my PSU, so I put them on top of the Duet reciever.
Why spend the money for an external DAC? The Duet is just fine. Upgrad the PSU, upgrade the analog out and you are done. Of course I have many, many external DAC's go through my system over the years and there is nothing special there. Some DAC's are good, some are bad. But why pay for one when the Duet does just fine on it's own after mods?
All I know is that I upgrade my analog out on the Duet, got the upgraded power supply, and send it all through a modded burson buffer and the sound I'm hearing on Loius Armstrong, Ella Fitzgerals, and Billie Holiday rivals the best ($10k) turntable setup I've heard. That's pretty serious.
Sure, but why? I have many external DAC's and they are OK, but why not just optimize the Duet itself? You seem to have a DAC fetish, which is quite curious. If I got an external DAC I'd just have to upgrade it as well, which seems pointless if I can upgrade the Duet directly....
Quote from: Tyson on 4 Sep 2008, 02:22 amSure, but why? I have many external DAC's and they are OK, but why not just optimize the Duet itself? You seem to have a DAC fetish, which is quite curious. If I got an external DAC I'd just have to upgrade it as well, which seems pointless if I can upgrade the Duet directly....I have no DAC fetish. I right now, I don't need a DAC. If I did, I couldn't use the Duet's DAC. I'm sure there are some people who already have a DAC they really like or want.BTW, if your Bolder Analog mods makes the Duet's DAC so good, why do you need the modded burson buffer?
Why does one need a separate preamp and amp? Clearly it's not a "need" as much as a "want". For the Duet, PS and analog mods get you to a certain level. The buffer gets you a bit further. Simple as that. The Duet is already a "DAC", so I see no reason to buy a DAC (Duet), and then buy another "DAC". What's the point? I don't know "Pat" and I've not heard his "mods". So, if you notice, I don't comment on his mods or whether or not it is overpriced. You however have no problem speculating wildly and ignorantly about other people's work. That does not make you look wise or informed, it makes you look like a fool. With regard to cost, I am neither poor nor miserly. I have spent what I've felt necessary to get a level of performance I am happy with. If you cannot or will not spend the money to achieve that level, there's no shame in that, but the fact is that your financial penny pinching is making you musically impoverished. That is your choice, and you have to live with it. I do not and will not.
