Broken ground bar on DVI-D cable... does it matter?
0 Members and 1 Guest are viewing this topic. Read 1357 times.
Tirade
I was trying to straighten some pins in my DVI-D cable that got squashed by the TV being placed down on top of the connector. Anyway I got the pins all straightened but I managed to break the flat ground bar off.
Is this pin even used? From what I gather its only used with DVI-I as the ground side of the analog pins but Im clueless. What would be the result if I tried to use it, could anything bad happen (bad meaning something breaks). Its a special made cable so its not that easy to replace...
Not exactly an audio questions but I wasnt sure what other forum to put this in. Theres got to be more electrical engineers in this forum than any other ;)
Tirade
Re: Broken ground bar on DVI-D cable... does it matter?
« Reply #1 on: 3 Mar 2008, 12:54 pm »
I guess I'll just test it and see  :|
arthurs
« Reply #2 on: 3 Mar 2008, 02:25 pm »
If it breaks, look here http://www.audiocircle.com/index.php?topic=51207.0
I'll send you a really good one for just the cost of postage!
Tirade
« Reply #3 on: 3 Mar 2008, 02:55 pm »
Thanks for the offer but I dont think that would help me ;)
This DVI cable is an internal DVI-D that is inside the TV. I had removed it to replace a bulb. Its a standard DVI-D cable except for 2 things...  one end has a 90degree connector (and there just isnt room for a standard connector) and it has these weird extra grounding pads/metal tab on each connector, I assume they are for additional grounding.
I tried to order a replacement from Samsung but they sent the wrong item and I was tired of waiting ;)
