1500 to 2000 cdp pick
0 Members and 1 Guest are viewing this topic. Read 2580 times.
2bigears
« on: 27 Feb 2008, 02:16 am »
 :D  is there a clear winner in this price point,need for a 2nd system??  used is best thks  Pat  :D
maxwalrath
Re: 1500 to 2000 cdp pick
« Reply #1 on: 27 Feb 2008, 02:55 am »
The best I've heard around this range would be a used modwright Sony 9000es, at this price you can get one with all the options, tubes, bells and whistles.
2bigears
« Reply #2 on: 27 Feb 2008, 03:37 am »
 :D  thks max,you don't see too many on the gon anymore latley ?????  they still hold their weight at this price point ??  :D
maxwalrath
« Reply #3 on: 27 Feb 2008, 03:47 am »
I'm admittedly biased towards modified gear, so you should take my rec. with a grain of salt.
That said, the Sony's were built like tanks, and were Stereophile Class A players I believe (which is a real crock, in my opinion, given how far above and beyond a Modwright 9000 was over a stock 9000).
I don't believe that any advances in cdp technology in that used price range over the last few years can counteract the low re-sale value of modded gear.  It helps that the Sonys were very popular, so what were $1200 Stereophile Class A players can now be found for a few hundred bucks.
« Last Edit: 27 Feb 2008, 04:05 am by maxwalrath »
maxwalrath
« Reply #4 on: 27 Feb 2008, 06:16 am »
You aren't near Philly by any chance are you?  If so you could give one a listen.
2bigears
« Reply #5 on: 27 Feb 2008, 06:34 am »
 :D  up in a 4 foot snow bank,Canada....sounds like modded MW gear is a good buy.... :D
zmanbands
« Reply #6 on: 27 Feb 2008, 12:29 pm »
Also VSE Vacuum State Electronics also Have great mods on the Sony S9000ES. This unit plays SACDS DVD's CD's but not CD-R's. If you have a lot of CD-R's this could be a deal breaker. Your modded 9000 by VSE will beat Players up to $16K. I have one and it's a dream.
saisunil
tube Research Labs (TRL) Modded Sony NV900ES with Battery Mod
« Reply #7 on: 27 Feb 2008, 04:06 pm »
Well for that money - you can get full battery mod done on Sony NV900ES by Tube Research Labs. I am waiting to receive a battery modded system while I listen to the TRL modded (non battery) unit. You may end up keeping this in your main system.
Give Paul a Call at Tube Research Labs.
Cheers
Sunil.
« Last Edit: 27 Feb 2008, 05:32 pm by saisunil »
Double Ugly
« Reply #8 on: 27 Feb 2008, 04:36 pm »
TRL equipment has received a lot of good reviews, but I'm skeptical of them and their products.
I spoke with Paul a while back about modifying a Slim Devices Transporter, and he said (paraphrasing) that it wasn't a suitable audiophile product, that it can't be made to perform well enough for use in a high-end system.
Since I own a modified Transporter, and since I've heard how good the ModWright Transporter sounds, suffice it to say I strongly disagree with Paul's assessment.  Other professional modification specialists (Dan Wright and Alex Peychev) seem wholly impressed with the Transporter's performance and capabilities, and since my experience mirrors theirs, I find Paul's comments curious at best.
JMHO...
chgolatin2
« Reply #9 on: 28 Feb 2008, 04:37 pm »
Or my Jolida JD 100 W/Level 2 mod for sale!!! :thumb: :green:
Philistine
« Reply #10 on: 28 Feb 2008, 07:16 pm »
JMHO...
Likewise, I've got both a Modwright TP and Bolder Modded SB3 - the TP is exceptional.  Guess we're spoilt for choice on this site, having access to Dan, Wayne & Steve (Modwright/Bolder/Emperical).  Even though Alex Peychev doesn't support AC I consider he has strong credentials as a talented moddifier also.  All of these guys, and my ears, can't be wrong.
darrenyeats
« Reply #11 on: 28 Feb 2008, 07:51 pm »
I think the plain Transporter, or SB3+DAC (e.g. Benchmark) will perform more than adequately for your needs. You would then have more funds to put into other areas that might bring a greater improvement.
I realise a lot of people here don't agree, but I thought it was worth giving my view. At least when you choose you'll have a wider selection of opinions to ignore. :-)
Darren
Philistine
« Reply #12 on: 29 Feb 2008, 12:10 am »
Darren
I think this is good advice - in addition I would also consider the Channel Islands PS for the SB3.
  • Speakers....What Speakers ?
« Reply #13 on: 29 Feb 2008, 06:14 am »
Hello Pat...
Here's one you might check out thats in your range....Cambridge Audio 840C.
Been hearing from friends and reading good things about it. 8)
So....whats in this 2nd. system ? Thanks.... :thumb:
2bigears
« Reply #14 on: 29 Feb 2008, 10:54 pm »
 :D  thks guys,hi Chris,the amp will be a VAC Avatar Super if UPS can find it ???? Lost in Calgary,hope it turns up.Not sure on speakers yet,but i have a pair of old 802 Matrix S3.Not sure i will use those but it's a start. :D
bunky
« Reply #15 on: 29 Feb 2008, 11:06 pm »
Hello Pat...
Hey Chris,i just bought a Black 840C and it was delivered here today.I will let her run nonstop for a week before i do any critical listening....thanks....WCW III
« Reply #16 on: 1 Mar 2008, 05:40 am »
Great bunky.....please post your comments after you've had time to listen......thanks !  :thumb:
doug s.
  • makin' music
« Reply #17 on: 1 Mar 2008, 06:58 pm »
buy my dac!   :green:  add any decent transport.  get sound as good as you will find in your price-range, & pocket the savings...  8)
http://www.audiocircle.com/index.php?topic=49382.0
doug s.
JoshK
« Reply #18 on: 1 Mar 2008, 07:00 pm »
I've heard good things about the Cambridge, even coming from really hard to please and experienced audiophiles.
HiFiSoundGuy
« Reply #19 on: 1 Mar 2008, 08:53 pm »
  For little more money you could try a Rega Saturn.... http://www.dagogo.com/RegaSaturn.html
