BEHRINGER F-CONTROL AUDIO FCA202 - anyone care to comment?
0 Members and 1 Guest are viewing this topic. Read 3187 times.
DerrO
Hi,
Is anyone using the BEHRINGER F-Control Audio FCA202, 24-Bit/96 kHz FireWire Audio Interface?  or can  anyone make any comments about this. Seems like a  simple solution - just plug and play on a Mac, but concerned  that it is so cheap that it surley cannot compete with the better ones out there?
Anyone care to comment on this?
Thanks - form someone who is trying to learn about these things
Derro
dB Cooper
Re: BEHRINGER F-CONTROL AUDIO FCA202 - anyone care to comment?
« Reply #1 on: 24 Feb 2008, 09:16 pm »
I wanna know about this device too. I have heard that they use a pretty good true-24-bit DAC in both the USB version and this one. Was considering the M-Audio "Audiophile" Firewire until I heard that a single improper (ie, without ejecting) disconnect could PERMANENTLY disable your firewire port. No thanks! Don't know if other FW soundcards like this unit carry the same risk.
kyrill
« Reply #2 on: 24 Aug 2009, 10:48 am »
Bump
I am investigating if this unit would be more than nice ( modded with a PaulHynes designed pws components, and modded further by audiosmile.co.uk to make stellar LP ( vinyl) conversions to a PC hdd?
turntable-->phono pre-->FCA202-->firewire IN laptop
anybody?
Crimson
« Reply #3 on: 24 Aug 2009, 03:58 pm »
Depending on how much the additional mods cost, it may open up more options (Apogee, RME, etc).
kyrill
« Reply #4 on: 24 Aug 2009, 04:10 pm »
forgot to mention it is for a Windows laptop. If i had a mac i would buy the Duet for this purpose
the clock upgrade and paul Hynes supply are world class and will not be found under 1500 dollar interfaces and even then..
chrisby
Re: well, not the Behringer, but
« Reply #5 on: 28 Aug 2009, 04:49 pm »
I recently acquired one of these:
http://www.rolandus.com/products/productdetails.php?ProductId=731&ParentId=114
more flexibility than required for basic computer audio playback, but since when has too many features been a real problem?  :lol:
Crimson
« Reply #6 on: 28 Aug 2009, 05:10 pm »
How does it sound?
