0 Members and 1 Guest are viewing this topic. Read 28716 times.
Hi,Alot depends on the design and parts quality etc, so it is very difficult to determine which tube is really best. For instance, the capacitors on the open market are not as good as custom caps that manufacturers can obtain. This one part alone will shift the results from one tube to another.Hope this helps.Steve
Quote from: Steve on 23 Feb 2008, 05:27 pmHi,Alot depends on the design and parts quality etc, so it is very difficult to determine which tube is really best. For instance, the capacitors on the open market are not as good as custom caps that manufacturers can obtain. This one part alone will shift the results from one tube to another.Hope this helps.Steve Agree 1005. There are NO best 6922s. Its all about synergy. Just keep trying different tubes. Now if you desribe the character of the tube your looking for we can help with that.brown
..... Do you think the tubes in a tube preamp can reverse compression in cds and vinyle recordings?
Doesnt the B.A.T. preamp use a Russian super ultimate military version of a 6DJ8 called 6H30 ?
Quote from: earwig on 29 Feb 2008, 08:37 amDoesnt the B.A.T. preamp use a Russian super ultimate military version of a 6DJ8 called 6H30 ? The 6H30 is a different animal entirely. It is closer to the 5687 then 6DJ8 family, but different still then the 5687. The Russian equivalent to the 6DJ8 is the 6H23p (6N23P) and the 6N1P is close to the 6DJ8, but not quite exactly the same.
What is your favourite 6922 or equivalent input tube, and how it sounds in your system relative to others?Thanks,Mike
