0 Members and 1 Guest are viewing this topic. Read 17206 times.
And then there are the "extremists". Come visit the single driver circle, where time/phase coherency, differences in sound between drivers, and crossover issues have all been resolved.
Most crossovers have their own group delay which causes the lower frequencies to be delayed relative to the high frequencies.Higher order filters cause more group delay than lower order filters....... etc
Daryl, thank you for the erudite discussion on XO phase delay. But ... so? But I think you missed the point of my post ... which is that, only if you listen to time-aligned speakers "straight on" (ie. pointing directly at your ears), will the time-alignment "work". If you don't toe in the speakers that much then you have destroyed the basis of the time-alignment calcs and you are, in effect, no longer listening to a time-aligned setup! ... and most people, for some reason, don't point their speakers directly at their ears.Regards,Andy
Daryl,here are a couple of links to some information on Transient perfect crossovers that you might find interesting. http://www.geocities.com/kreskovs/John1.htmlhttp://www.musicanddesign.com/tech.htmlScotty
*Plug* (Not shameless)To add to that, keep in mind that much of what we hear is not just direct sound, but reflected sound. With non-coax speakers, the path length differences are great, as are the cancellations created in the frequency domain.
The reason ... that the mathematics of their time-alignment only work when you have the speakers toed-in so that they are perpendicular to a line pointing towards your ears ... and most owners never have them toed in this much!!??
Good point Andy. That's why I'm careful to use the term "extended range driver" not "full range driver". (It also saves a good many "unfruitful debates".)As Mark indicated, my single driver speakers are about as close to "full range" that you're likely to find. And most designers recognize that below 200 Hz, the ear is less sensitive to delay/phase errors anyway.One of the primary places that audiophiles have "lost their way" is believing that response below 35 Hz or above 20,000 Hz or that spls above 110 dB are essential (or at least more important than the six octaves in the middle reproduced well at more "real world" spls. Much grief (and marketing successes) have come from such a pursuit.
Quote from: JLM on 20 Feb 2008, 12:17 amGood point Andy. That's why I'm careful to use the term "extended range driver" not "full range driver". (It also saves a good many "unfruitful debates".)As Mark indicated, my single driver speakers are about as close to "full range" that you're likely to find. And most designers recognize that below 200 Hz, the ear is less sensitive to delay/phase errors anyway.One of the primary places that audiophiles have "lost their way" is believing that response below 35 Hz or above 20,000 Hz or that spls above 110 dB are essential (or at least more important than the six octaves in the middle reproduced well at more "real world" spls. Much grief (and marketing successes) have come from such a pursuit.I agree with you that "extended range driver" is a more appropriate term. However, I totally disagree with your contention that below 35Hz is not important - nor above 20Khz. You obviously don't listen much to Bach's organ music if you think that below 35Hz is unimportant. Regards,Andy
