Amp Hum
0 Members and 1 Guest are viewing this topic. Read 2430 times.
ashtarul
Amp Hum
« on: 16 Feb 2008, 01:50 am »
My MPS-2 and 14B SST gives out a low humming noise. The hum is audible when standing close to the amp (for when changing volume level, switching off, etc). It is not audible at listening position. Is this normal? If not, what could be the cause and how do I fix this?
Ash.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Amp Hum
« Reply #1 on: 16 Feb 2008, 03:24 pm »
Ash.
Hi Ash,
There is usually some small level of hum from a transformer -but if it is excessive you may have DC on the power line.
james
ashtarul
Re: Amp Hum
« Reply #2 on: 16 Feb 2008, 06:17 pm »
Thanks James. I recall reading somebody's post regarding something similar but I'm too lazy to search for the thread now. I think the Torus was recommended in his case. The hum isn't loud so I'm assuming it's normal. Having said that, I'm no electrical engineer so if you can excuse my ignorance :oops:, how does DC get into the power line and how do you avoid it?
Thanks for your time.
Ash.
satfrat
Re: Amp Hum
« Reply #3 on: 16 Feb 2008, 06:25 pm »
This thread might be of some help to ya Ash, http://www.audiocircle.com/index.php?topic=50990.msg457632;topicseen#new  :dunno:
Robin
ashtarul
Re: Amp Hum
« Reply #4 on: 16 Feb 2008, 07:13 pm »
Thanks for that Robin. I'll try to make sense of it.
satfrat
Re: Amp Hum
« Reply #5 on: 16 Feb 2008, 07:51 pm »
JoshK just posted 2 articles that might be of some interest to ya: http://www.audiocircle.com/index.php?topic=51068.msg457845;topicseen#new
http://sound.westhost.com/earthing.htm
GROUNDING PRACTICES IN CONSUMER AUDIO
I really know a much about this stuff as you do evidently, the "gray matter" between my ears will never be up to pare with those who have all this stuff figured out.  :scratch: But if I can find something that works for me, then I'm a happy camper. Hopefully you'll be able to do the same.  :thumb:
Robin
ashtarul
Re: Amp Hum
« Reply #6 on: 17 Feb 2008, 03:59 am »
 :scratch: :lol:
