Volex PCs - Wire Label
0 Members and 1 Guest are viewing this topic. Read 2043 times.
JDUBS
« on: 14 Feb 2008, 04:13 am »
Hey Guys
Just ordered four 17604s from Newark.  I got them today and the plugs say Volex but the cable itself says "Tongyuan LL110486".
I'm planning on cannibalizing the conductors in one of these for use in a Felicia power conditioner I'm building...just want to make sure its got the "good" wire in it.
I'm curious if this is consistent with other Volex PCs out there.
Jim
yo2tup
Re: Volex PCs - Wire Label
« Reply #1 on: 14 Feb 2008, 04:22 am »
I remember reading on headfi somewhere that the volex 17604 sold now is not the same volex 17604 people 'raved' about in the past.  The original cable was made in US, and the current cable is made in China.  I'm not sure of how they compare though.
JDUBS
« Reply #2 on: 16 Feb 2008, 04:21 am »
Thanks yo2tup.  I have some other Volex cables and the cable is quite a bit beefier.  Annoying!
-Jim
Gaara
« Reply #3 on: 16 Feb 2008, 12:19 pm »
Jim,
Ric Schultz quote: "Looking for a few of the 17604 cords with the folded brass male blades....newer cords are made in China and have straight tinned blades." I talked to Ric and he was never able to find them from current distributors, he was looking for them for his EVS amps.  I bought 10 and am happy for what I paid, but much prefer the older style ones.  Every once in a while you will see someone selling them, but they usually garner a relatively high price.
James
rramraj
« Reply #4 on: 16 Feb 2008, 01:40 pm »
Hi James,
Any idea if the ones marked Made in Mexico are similar to those made in the US. Appreciate any feedback. Regards :scratch:
Gordy
« Reply #5 on: 16 Feb 2008, 01:59 pm »
The original cords have the folded brass blades and are marked: 14-3  SJT  (UL)   E204241-C----CSA    LL2126-c  FT2  Shielded    ...FWIW
Gaara
« Reply #6 on: 16 Feb 2008, 03:53 pm »
Hi James,
Nope.  I was under the impression that all the older 17604s were made in Mexico for Volex.  To my knowledge there are no resellers out there who have stock over the older style ones.  I contacted Ric about this and he confirmed it a few weeks back.
JDUBS
« Reply #7 on: 18 Feb 2008, 12:11 am »
Thanks everyone....just what I was afraid of!   :(
I'm curious if the actual wire is still Belden 19364.  I guess I'll go ahead and cut one open and find out.
-Jim
jb
« Reply #8 on: 27 Feb 2008, 10:46 pm »
-Jim
Hi Jim,
Just what do expect to find after cutting one open? A little fortune cookie tag that says "genuine Belden 19364?" The Belden part number refers to the entire cable: conductors, insulation, shielding, jacket, etc. If it doesn't say Belden 19364 on the jacket then it is not Belden 19364. It may, in fact, be equivalent to, better than, or worse than Belden 19364 but I doubt you would be able to unequivocally know which just by looking at it.
BTW, Belden 19364 is hardly the best bang for the buck power cable. That honor belongs to Belden 83xxx series. Better shielding, better insulation (Teflon instead of PVC), lower inductance, two, three, or four conductors, the latter allows star-quad geometry, etc. Just my opinion.
JDUBS
« Reply #9 on: 28 Feb 2008, 12:18 am »
-Jim
Hi Jim,
Yes!!  I did expect a fortune cookie tag, but to my surprise there was not one!  19364 was not on the jacket.
