SP 1.7 issue with bypass
0 Members and 1 Guest are viewing this topic. Read 1589 times.
Tony1
« on: 10 Feb 2008, 02:01 am »
I have a few SACD's that I listen to in multi-channel bypass mode.  Hit play and all I can hear was  the L and R speakers only in the multi chan bypass mode.  Verified all settings several times on SP 1.7 and SACD player.  2 Chan bypass works fine but the multi bypass only outputs in the front 2 channels.   Has anyone encountered this issue?
Tony
Phil A
Re: SP 1.7 issue with bypass
« Reply #1 on: 10 Feb 2008, 04:10 am »
What player and what discs were you using?
pantone172
« Reply #2 on: 10 Feb 2008, 05:19 pm »
check to make sure the SACD is in fact multi-channel. some are stereo only.
Tony1
« Reply #3 on: 12 Feb 2008, 06:27 am »
Found the problem, it was set for Stereo instead of multi channel.
