0 Members and 1 Guest are viewing this topic. Read 8537 times.
So I think instead of buying another pair of speakers that I don't really need, I should get my music computer (Dell Poweredge 600SC) to where I want it. That means a 22" or so LCD, and a big hard drive...in the 750GB to 1TB range.What brands of monitors have you guys had success with? I was thinking Samsung...
As for hard drives, my mobo doesn't have SATA support, but I guess I could add a card for it. Seagate makes a 750GB EIDE drive I was looking at...
24" Dell LCD widescreen is highly recommended!
Just curious, how much would I be looking at for a good RAID 5-capable controller? I may be holding off on the HD upgrade for now (haven't yet filled up my 250GB internal), but that sounds like the way to go in the future. My machine has three empty 3.5" drive spaces, plenty of room.
Most of the 22" LCDs use interpolation to provide 16.2 million colors.To ME, they look pretty good, but I'm not as picky about that as my sound We have had good luck with Samsung, Viewsonic, and Hanns GAs far as the big hard drive, I would recommend a couple of things.1 - store your data on a separate physical drive from the Operating system and applications.2 - back up your data to an external drive, daily. There are a lot of good programs to automate this for you.3 - Once you're doing the second one, then consider RAID. I would do a mirror of 750 or 1Tb drives. That will protect you from a single drive failure, but not from accidental deletion of data (that's what the external drive is for) The read performance boost you'd get from RAID 5 isn't really needed to stream music. For HD video, it might make a differenceAgreed on the 24" Dell - that's a nice monitor
Cool Bryan, thanks. An external USB drive with a power switch might be a good idea too.Anybody know of any places to shop other than Newegg or BestBuy (for good prices)?Bob
