0 Members and 1 Guest are viewing this topic. Read 3906 times.
TVs have much lower resolution, you wouldn't want them for computer use.
Thanks for the replys, guys! I'll check out the 22" Acer, but the 24" is definitely overkill for my parents. Of course, if it were me, I'd be gazing longingly at a reburbed 30" Apple Cinema Display! For reference, it appears that there is yet another resolution with a dot pitch similar to my target - 20" 1400x1050. The LCD market has really exploded since I bought my 19" 2+ years ago!19" 1280x1024 = 86.27 PPI or 0.2944 mm dot pitch20" 1400x1050 = 87.50 PPI or 0.2903 mm dot pitch22" 1680x1050 = 90.05 PPI or 0.2821 mm dot pitch(PPI = pixels per inch)
