Cool device
0 Members and 1 Guest are viewing this topic. Read 2162 times.
Brad
Cool device
« on: 2 Oct 2003, 12:58 am »
It's the Terratec Phono Preamp Studio USB
Lists for $199 and lets you connect your turntable to your PC for 'digitizing' your vinyl.   Sacrilege maybe, but some of my music is only on vinyl and this is a good way to listen to it at work.
Terratec
Marbles
Cool device
« Reply #1 on: 2 Oct 2003, 01:07 am »
Looks like a very cool product, thanks for pointing it out!
Brad
Cool device
« Reply #2 on: 2 Oct 2003, 01:36 am »
A quick check shows the pro music shops have it for about $125.
There's a new one on *bay with buy it now for $119.
Not too bad.
Looks like they make some decent sound cards as well.
JoshK
Cool device
« Reply #3 on: 2 Oct 2003, 03:48 pm »
Yes, thanks for this, I was just about to compile all my LPs to my computer, mostly for ease of play when waltzing around the house.  Also, I need to burn a bunch of the LPs for my dad, since that was the deal.
JoshK
Cool device
« Reply #4 on: 7 Oct 2003, 10:18 pm »
As cool as this may be, I still think I would rather have the M-Audio USB Audiophile.  It is the same thing as the internal M-Audio Audiophile 24/96 card but external via USB connection.  This should provide even lower noise floor.  It has a gamut of inputs and outputs including RCA input/outputs and SPDIF digital.   It doesn't have phono level inputs but you can just use your existing phono preamp into the line level inputs and voila.
The reason I like it better is due to its more flexible use and I would likely use this a lot more, for  more than just vinyl archiving.  Plus it is powered via AC not USB which is suppose to lower noise quite a bit.  The terratec phono usb is powered via USB.
Brad
Cool device
« Reply #5 on: 7 Oct 2003, 10:53 pm »
My existing phono preamp is built into my receiver, which doesn't have L/R preamp outs.
I got sniped on the auction at the last minute.....
Time to build a bugle, I guess   :)
michael w
Cool device
« Reply #6 on: 7 Oct 2003, 11:45 pm »
Brad;
If your receiver has no preamp outputs you can always use the tape outputs.
cheers
Brad
Cool device
« Reply #7 on: 8 Oct 2003, 01:18 am »
I'm kinda between systems right now and just using the receiver to get by.
I will probably go ahead and get a good phono stage when I rebuild.
The USB device would let me enjoy my vinyl for now (and at work through iTunes)
