Other Tube Preamps
0 Members and 1 Guest are viewing this topic. Read 3628 times.
guest1632
  • Guest
Other Tube Preamps
« on: 23 Jan 2008, 08:19 pm »
Hi all,
Anyone know of this Audio Experience Symphonies V2R with remote tube line preamp $448" preamp? It is listed on Audiogon. Sounds like a killer deal, but wanted to know more about this one first.
Thanks.
Ray
bunky
Re: Other Tube Preamps
« Reply #1 on: 23 Jan 2008, 11:32 pm »
Hi all,
Thanks.
Ray
Hey Ray, a friend of mine from another forum owns one and says it sounds good.I just read a post on the Agon forum that claims that the pre's leak DC and send certain amplifiers into protection mode. Caveat Emptor :o
guest1632
  • Guest
« Reply #2 on: 23 Jan 2008, 11:52 pm »
Hi all,
Thanks.
Ray
Hmmm, got a link? Just now became active on audiogon.
Ray
Photon46
« Reply #3 on: 23 Jan 2008, 11:56 pm »
Ray, there's been a bit of talk about this preamp over at Audiogon and I think I remember some at the Asylum as well. The consensus seems to be that it's cheaply built and not a great performer as it comes from the factory. However, I've read of those who went through it and made higher grade parts substitutions and it emerged a suposedly much better performer. Personally, I can't imagine why I'd take a chance on a product that has no stateside support system when I could buy a nice used preamp of a known quality with for about the same price. A search of their archives would be worthwhile if you want to research it further.
guest1632
  • Guest
« Reply #4 on: 24 Jan 2008, 12:00 am »
Hi Photon46,
This is the kind of stuff I'm looking for. If it's built like crap, don't want it. Thanks for the headsup.
Ray
guest1632
  • Guest
« Reply #5 on: 24 Jan 2008, 02:25 am »
Reading in the forum, yes this problem did occur. But according to the manufacturer, it has been rare like twice or so in the last 3 years. There is one of the two coupling caps you remove, problem solved. That one I don't know about, which cap to remove.
Ray
gus6464
« Reply #6 on: 26 Jan 2008, 08:55 am »
I too am looking to upgrade to a tube preamp/ SS amp setup in a couple of months and the Ming Da MC 7R has bought my attention. It looks very well made for a very good price. Response Audio also mods them as well.
http://www.pacificvalve.us/MingDAMC7R.html
Rocket
« Reply #7 on: 26 Jan 2008, 09:22 am »
Hi Ray,
What about the juicymusic merlin preamp.  $795us and its made in the US.
http://www.juicymusicaudio.com/products.html
Regards
Rod
guest1632
  • Guest
« Reply #8 on: 26 Jan 2008, 09:32 am »
Hi Ray,
Regards
Rod
Hi Rob,
Won't sound as good as the Peach?
Ray
ajzepp
« Reply #9 on: 26 Jan 2008, 10:13 am »
I just received my Mapletree Line 2A SE this past week. Want to know how much difference it made with my 2-channel music? I'm using only a little iPod Nano as my source since my Denon 2900 universal player is acting up...and it's the best sound I've ever had with my system. It's built very well, and Dr. Peppard of Mapletree is a really great guy to deal with. So far, I'm thrilled with the product.  :thumb:
Bill Baker
    • Musica Bella Audio
« Reply #10 on: 26 Jan 2008, 02:55 pm »
Hello gus6464, the Ming-Da MC-7 is a very good valued preamp right out of the box. Unfortunately, I just received word from Pacific Valve that they are out of stock on this unit and should have more in about 2 weeks.
 I only mention this as Pacific Valve has received orders for our modded unit only to find out they are back-ordered.
lcrim
« Reply #11 on: 26 Jan 2008, 05:09 pm »
I just noticed that there's an Eastern Electric MiniMax preamp for sale here. http://www.audiocircle.com/index.php?topic=50165.msg450180;topicseen#new
I'm presently an owner of one and I also feel that its a jewel that's very adaptable through tube rolling and build quality is simply first rate.  I like mine very much.
JuicyMusic
    • http://www.juicymusicaudio.com
« Reply #12 on: 27 Jan 2008, 09:33 pm »
Hi Ray,
Regards
Rod
JUST AS AN FYI - - I am going to put a really special hot-rodded Merlin on the "reverse auction" block later today. See "Industry Ads" later for details.
JuicyMusic
