Which of these three integrated amps under $1000 would you pick?
0 Members and 1 Guest are viewing this topic. Read 4412 times.
Wind Chaser
All integrated and all nicely priced.
Little Dot T150 - A Tripath/tube hybred for $500?
http://www.obadimports.com/catalog/item/4377302/4639260.htm
Or an EL34 $400?
Specifications
· Tubes: EL34B × 4 (Output Tubes) 6N1 × 4 (Voltage amplifiers and drivers)
· Maximum Output: 52W x 2 (8Ω)
· Output Jacks: Two channels with two groups gold plated jacks
· Output Impedance: 4Ω and 8Ω
· Input Sensitivity: 0.3V
· Input Impedance: 20KΩ
· Input Jacks: 4 Groups gold plated Isolated RCA jacks (CD, DVD, Tape, and Tuner)
· Distortion of Harmonic Wave: ≤2% (at 40W)
· Frequency Response: 20Hz ~ 60KHz (-2dB 10W)
· Signal-to-Noise Ratio: 85dB (A weight)
· Supply Voltage: AC 115V, 60Hz
· Power Consumption: 220W
· Net Weight: 17kg
· Shipping Weight: 22kg
· Shipping Dimension: 60cm x 44cm x 32cm
Or how about a KT88 PP for $700?
Specifications
· Tubes: KT88-98 × 4 (Output Tubes) 6N8P × 4 (Drivers and Cathode followers) 12AX7B × 2 (Voltage amplifiers)
· Maximum Output:
                           30W x 2 (8Ω and Triode Mode)
                           60W x 2 (8Ω and Ultra linear Mode)
· Input Jacks: Gold plated Isolated RCA jacks, 4 groups (CD, DVD, Tape, and Tuner) on rear, and 1 group on front as the input of post-stage mode
0.25V in integrated mode (CD, DVD, and Tuner)
0.6V in pure post-stage mode (Front input connectors)
· Distortion of Harmonic Wave: ≤1.5%
· Frequency Response: 5Hz ~ 80KHz (-2dB)
· Signal-to-Noise Ratio: 90dB (A weight)
· Power Consumption: 280W
· Net Weight: 23kg
· Shipping Weight: 30kg
· Shipping Dimension: 60cm x 52cm x 36cm
Meicheng
Pardon me, where can you get those tube amps at those prices?
  • Speakers....What Speakers ?
Those tube integrated amps are from MaRKHILL Holdings....
loki1957
I'd like to know that as well. Markhill doesn't give prices and I don't see any tube amps at the link you proved.
doug s.
  • makin' music
i'd definitely get the mc100b, for several reasons.  first of all, the lildot doesn't have tubes, so that one is out.   :wink:  between the other two, the 100b is dual mono, has adjustable bias, and can be run either triode or ultralinear.
you can get one for ~$500 shipped via surface mail, or ~$600 shipped via airmail, if patient:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110214812681
but, the mc10l can be gotten ridiculously cheap, if patient, (<$250 shipped surface mail; <$375 shipped airmail); & it looks as tho the latest iterations allow for tube biasing:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280191156221
doug s.
Wind Chaser
The Little Dot does have tubes - (EF91/CV138)on the pre-stage PCB.  Tripath with tubes in front can sound very nice.
Of the two tube units with pictures, the corresponding prices I posted were from a Canadian supplier who offers a warranty and servicing here in Canada instead of having to ship the unit back overseas.  Buying an amplifier in Canada will cost more initially as shipping it to North America is built in.  Having it shipped out of Canada instead of Hong Kong means it will ship much quicker to its final destination.  It also means warranty related issues will not be as cumbersome as having to ship the unit back to Hong Kong as.  The Canadian vendors warranty is as follows...
· One month for the vacuum tubes;
· One year for the system (vacuum tubes not included);
· Two more years repairing without labor charge;
· Warrantee duration effective from 10 days after shipping date;
· Buyer pays all necessary shipping costs (including return) to our service center in the area of Toronto, ON, Canada.
doug s.
  • makin' music
ya, i know, the lildot has a tube pre, but its amp is s/s...  for some, that's ok, for me, i prefer tubes; ymmv.
you are correct that you will always (usually always?) get better service for the higher price paid to an importer, as opposed to buying direct from the source.  at these prices, tho, i would choose to buy direct; if i had any problems, i would yust pay for the repairs out of pocket, to a local tech.  in that case, i would still likely be no worse off financially as if i'd paid a higher initial price.  and, i would have less hassle yust taking it to my local tech; dealing w/the importer as it is, i would still have to ship to toronto, in this case.  still a hassle & expense.  now, if i lived in toronto...   8)
doug s...
gus6464
Thank you so much for posting that Little Dot T150. I have been searching around for a tube hybrid integrated for a while that could offer around 150 watts and all the ones I have found are over $1000 so I was just going to go with a tube pre and separate SS amps. I am upgrading to Mark and Daniel Rubies at the end of the year and needed something like this to power them but this is half the price.
Wind Chaser
Right on!  Let us know how you like it.  NOS CV138 tubes by Amperex, Mullard and Seimens are very inexpensive.  Usually $5 a pop from what I have seen.
gus6464
Ohh nice thanks for the tip I will be ordering when tax refund comes in about a week hopefully.  :D
Wind Chaser
I ordered a Little Dot T-100, why not?  It's cheap and from what I have heard sounds decent.  It should arrive any day, but one of my speakers has an issue necessitating a rebuild, so you might be listening to yours before I get to hear mine.
gus6464
Lol I just noticed something from the pictures of the Little Dot T150 and T100. How does one change the source? All it has it volume and power button. Is it psychic and knows what source you want to play?  :lol:
Wind Chaser
Remote control!
gus6464
Remote control!
Ohh haha guess I have never seen an integrated or pre where you can only change source with remote. It would suck if you lost the remote. :(
Wind Chaser
Hardly.  Just buy a new one.
RAW
I have the Little Dot T from the shoot out i purchased it from Danny.
Love it.This amp drives our Apex III with out a hick up nothing.
Local to the distributor I emailed and asked for someone to contact me about the new 150.12weeks so far no response.
Wind Chaser
Al, try calling him.  If you leave a message, he'll get back to you.
I thought about asking you if you'd like to sell yours, but I lucked out as Obad had one T-100 left.  I've got some NOS Mullards on the way from Argentina.
RAW
Yes I may just do that.
Yes you had a listen to this one here, be interested to see what you think of the tube change in the 100 :thumb:
