B100 volume control wobble ?
0 Members and 1 Guest are viewing this topic. Read 1230 times.
niels
« on: 18 Jan 2008, 07:13 pm »
You guys that have B100, does your volume knob also wobble a bit when you touch it ?
Kris44
Re: B100 volume control wobble ?
« Reply #1 on: 20 Jan 2008, 03:54 pm »
I have a BP-16DA pre, no wobble.
Kris
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 20 Jan 2008, 04:20 pm »
Sounds like the knob needs tightening using an 'allen key' in the small hole in the volume knob.
james
niels
« Reply #3 on: 20 Jan 2008, 05:31 pm »
Yes, funny. I have had it off several times, cant see anything wrong with it really. There is only one way to mount it, the rod from the volume pot has like a little recessed hole in it where the screw needs to be.
When you grab the volume control with two fingers and very gently rock it, then it is loose. It can move from side to side.
