Mullard 7247 (12dw)
0 Members and 1 Guest are viewing this topic. Read 813 times.
pbrstreetgang
Mullard 7247 (12dw)
« on: 15 Jan 2008, 08:52 pm »
Hi, I have four pulled 7247s and looking through tube guides it says a 12 AX7 can be used for a 7247 but not a 7247 into a 12ax7 spot- is this correct?
jon_010101
Re: Mullard 7247 (12dw)
« Reply #1 on: 15 Jan 2008, 09:16 pm »
Please don't stick that in a 12AX7 slot!  The 7247 is literally half of a 12AX7 and half of a 12AU7, and should be used only in applications designed for a 7247.  While some guitar folks will arbitrarily mix 12A*7 twin triodes in their amps, it generally won't lead to anything good in an audio application.
