0 Members and 1 Guest are viewing this topic. Read 3102 times.
my first foray into tubes! hope the next guy likes it as much as i did. i am switching up to some dared monoblocks. the almarro is sold, thanx to everyone who was interested.
is it SEP? That is the only way I know to get 5w from a single EL84.
good luck. but, if you are using efficient speakers & only need 5wpc, don't be surprised if you find yourself looking for another a205a mkll... doug s.
Quote from: doug s. on 7 Jan 2008, 07:39 pmgood luck. but, if you are using efficient speakers & only need 5wpc, don't be surprised if you find yourself looking for another a205a mkll... doug s.Not if you have 4 ohm speakers, right doug? Lin
lin, i would suspect you're right, as the almarro a205a mkll (later iterations, at least), has taps for 8 & 16 ohm speakers. i have never tried 4 ohm speakers w/my amp. but, if i had a pair of 4 ohm hi-efficiency speakers, i would definitely query almarro about using this amp to drive them, because it really is a nice amp...doug s.
Quote from: doug s. on 10 Jan 2008, 12:48 pmlin, i would suspect you're right, as the almarro a205a mkll (later iterations, at least), has taps for 8 & 16 ohm speakers. i have never tried 4 ohm speakers w/my amp. but, if i had a pair of 4 ohm hi-efficiency speakers, i would definitely query almarro about using this amp to drive them, because it really is a nice amp...doug s.Doug,I just sold an earlier model (which I was very fond of, but too many amps) that was rated for 8 and 16 also, they are not really optimized for lower imp.I posted because I saw in another thread that you were using a 205 to drive your Fostex FEs in series and before I was wondering (from a pic you posted) why you were not running the two drivers in parallel. Lin
