Getting toasty
0 Members and 1 Guest are viewing this topic. Read 1491 times.
Carlman
Getting toasty
« on: 25 Sep 2003, 07:58 pm »
I moved and therefore my AKSA moved with me... I have the 100W Nirvana.  Previously, it got a little warm but, nothing major.  Now, it gets very warm and I was wondering if people could suggest a few things to check.
The amp is situated in a shelving unit from Ikea that's made for a TV... it's one of those, low, flat things with wheels.  There's 2 'holes', equal size, about 20" wide and ~5" tall that form the base.  They are open in the front and back.  The amp fits neatly inside but also appears to have plenty of air to move.  But, maybe it doesn't.  It was in the bottom of a large entertainment center closed cabinet before.
My bigger worry was that the power was wrong.  I will measure the voltage tonight.  I wish I could test it with a load so I could know what was happening when the amp was sucking more power out of the wall.
In any case, is the space too small?  Could voltage be a problem?
Carl
AKSA
Getting toasty
« Reply #1 on: 25 Sep 2003, 09:45 pm »
Hi Carl,
Large power amps passively cooled need a lot of air.
I'd suggest removing the amp briefly from its present position and running it for a day or so to check temperature.
This way you get a handle on how much air flow is necessary.
Hugh
